I wish it was, but checked that previously. By following the trail it could only be dripping down from the valve gasket (preferred) or coming from on top of the turbo. Only seems to leak after "proper' drive, not idling in driveway, so oil under pressure by the looks of it.
The oil line to the turbo could be split but I think you are right, the washers for the banjo may need to be replaced. :(
I may be driving up to Sydney this week, want me to fix it for you? Swap you for a cruise install. lol.
Took her out for the first half decent drive with it, to get acquainted and such.
Very happy with it. I did find it a big laggy for an NA so Im thinking Im going to have to put a kit in the gearbox.
The guy I got it of said it was a Four wheel, turns out its rear wheel.
Haha, I would be tempted to drive the 8hrs to Sydney if you were serious. But I know you have that cruise mostly sorted now, so I have nothing to trade (except some folding plastic).
bought some new upgrades over the weekend, dual stage turbosmart boost controller, cooling pro FMIC kit, 550cc bosch injectors, walbro gss342 pump.hopefully my r33 will sell pretty quick so i can buy a hypergear tr43, lowmount manifold, and nistune to get it all sorted before sau nationals this year :D
Edited by OMY31T
dirty great box of Greddy goodness arrived today: that would be my suction kit... :)
waiting on Z32 afms which are on their way, and Nismo engine mounts: excitement!
Oh, and PWR ended up being a lousy bunch of not very nice people: The best they offered was a brand new radiator to my previous spec (inbuilt fluid coolers, triple cross-flow, etc) at a discounted rate.
Given that I would only expect it to last 18-24 months, pretty sure I'll pass, and buy a Jap name-brand unit (thinking Blitz), and run external oil and trans coolers... More than mildly disappointed at the outcome, but what can you do?
I will NEVER recommend their product to anyone!
bought some yellow jacket coil packs off ebay the other day fitted them had a missing issue then upgraded spark plugs (which I should have done in the first place) and now she runs a million bucks :)
Cruising on the highway and noticed the car was surging, gf pointed out that the torque split gauge was nearly on 10
Looks like I'm up for new rear tyres to match the new fronts :-(
Hi guys! I'm new to this site. I've got myself a nice 260RS in 2010. Since then I've had HKS hard piping put in, 3" turbo back exhaust, Nismo clutch, rebuilt gearbox, spitfire coils and a haltech ecu installed and tuned. It came with Tien coilovers. Now I'm looking to do a single turbo conversion in a few months just to bring spool up a lil.
What did you decide on in the end?
Still haven't decided; tossing up a 2860RS or 2871 core.
Exhaust side of both is identical, but the compressor exducer dimensions are 11mm different, so I'm not 100% sure.
Also the 2871 has thee trim options, 48, 52 and 56. On my SR I've had both the 48 and 56. I noticed no difference in boost response but did notice the 56 had more power up high.
On my SR it was making 18psi by 3800rpm with .64 exh so we could assume the vq25 would deliver 18psi around 3000-3200? Check with brad what his response is like as he uses a 2871 on his M35 but I don't know what trim version. I'd assume 52 trim as this is the most common version being a hks gtrs spec.
If your after closer to factory response I'd go the 2860 wheel, I will when mine fails but hopefully a while away still.
Edited by slippylotion
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
