Nice looking turbo Dale. :wub:
Looking forward to your review; I can see myself changing to something like that.
Really not happy with your current setup Leon? Still too laggy?
I just installed my guages that go under (or above? need to work that bit out) the stereo.
When I bought, it had one of those MP3 player drawer things (which is now for sale) to connect to the stereo, but the stereo only has output to an amp, so it was completely pointless.
Does anyone know what order they go in on a stock Stag? is it guages, climate control THEN stereo, or a different order?
Cheers,
Ian.
I've had the car pulled apart trying to fix an oil leak & just haven't had the time to work on it. In reality I haven't driven more than a few hundred K's since it was installed. With some tuning I may be able to make it more acceptable to me.
More likely, I will put it back together, take it to Willowbank to set a time & then swap it to something like Dale's. I have my doubts that I can get it to a point where it will suit how I like to drive the car, but I'll see - eventually.
Ordered some new rims for bigbird. Got a crack in an existing weld on my enkei rim. Didn't even realise the rim had been welded.
New rims are Advanti Stage(a) Drift 17x9 +15 Tires still 235/45/17
post-58831-0-41266500-1343377014_thumb.jpg post-58831-0-18692400-1343376999_thumb.jpg post-58831-0-99514300-1343377006_thumb.jpg
Nice clearance to the coilovers now.
Also found these !
The guys at o1g are awesome
Fired my new engine package up for the first time. slight miss (over fuelling) need to have a play with the niss tune, and a oil leak from new oil cooler pressure sender. all in all very succsesful considering the loom modifications required to chuck the neo into a s1. as well as the fuel set up changes and manual conversion at the same time expected more hicups. was good to hear the nice lump of the pon cams ocasionally even through the miss lol. just need to bleed clutch up now sort a few more things out then some tune time. 6 months off the road is too long hanging out to drive the old girl. should only be a couple more weeks. Then i can feel like a stag owner again
Let me know how you go, and we can see if we can do a deal if it helps. Is it that bad? I'd imagine with the F-con I can tune any issues out.
Will do - maybe a swap of some sort could be on the cards? Not sure if tuning can totally eliminate lag. I suppose programable boost control can help somewhat, & supposedly retarding timing can also help. I should stop whinging about it, lol, & just get on with making it work.
Also, just because I think it's too laggy doesn't mean someone else won't be raving over it.
Must be time for a cruise then Jase! About time, needs more pics!
yeah i think we are all due for a stag cruise . not sure how to get pics up as i use my smart phone
for the net. might have to use image shack or something as it wont read pic files straight of my phone
got new tyres fitted today, bought some falken FK-452's.. hopefully they will be fairly grippy :D has a little issue going from 235 up to 245... 2 much low, camber in the ass was that bad, that the tyres were on the coilover spring perch haha, and i have 19x8.5 @ +12 offset if thats any indication of the camber haha.
You don't have too much camber - your wheels are too big. I run 3deg neg camber front and rear on 17x9 in rims with 255 40 17 tyres which gives me a better contact area and also lowers the cog c/w 19in rims:
and my cheapo track rims 17 x 8.5in on slicks:
what is your offset... those 17's are a shitload wider than mine, my wheels sit inside the guards, even with the car raised up....... and they are a +12 :S also, if your telling m, in that top pic you have 3 deg neg camber, i must have about 15 deg neg, because all my wear on the old tyres was only about 1.5 to 2" wide lol, rest of the tyre was new hahaha. my car has a takeros body kit, the side skirts are like a step they are that wide, the bottom of the tyre is inline with the kit, the top was atleast an inch in and under the guard, and almost on the spring perch... its was a bit ummm... unrealistic really, but fun to have it dumped for a while.. not very practical, i had to raise the coilovers 45mm in the rear to even get the top of the tyre close to flush with the guard :D as i said, fun for a while, although it was like driving a commodore lol, but it looks like a 4wd again now.
Edited by OMY31T
Last week had my driver side front repaired after an accident a few months ago and finally fitted some 18's to the car... she's now looking mint but needs to be dropped an inch still i recon.
Also pressed in some new Inner Lower control arm bushes the other day; mine weren't damaged, but the new ones look to be much stiffer.
This should help remove some deflection in the LCA, and still deliver good ride quality.
Also did an all over suspension bolt check; one of my rear links needed nipping up at the Swaybar.
If you have a chance, and have been doing any work on your suspension in the last month; get under and check; not just visually, with a spanner.
Cleaned out the AAC valve today. It's fixed an idle problem that I was having, and the car also feels like its revving a lot smoother.
Edited by 180fan
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
