What Have You Done To Your Stagea Lately?
Hanso
I just installed my guages that go under (or above? need to work that bit out) the stereo.
When I bought, it had one of those MP3 player drawer things (which is now for sale) to connect to the stereo, but the stereo only has output to an amp, so it was completely pointless.
Does anyone know what order they go in on a stock Stag? is it guages, climate control THEN stereo, or a different order?
Cheers,
Ian.
Really not happy with your current setup Leon? Still too laggy?
I've had the car pulled apart trying to fix an oil leak & just haven't had the time to work on it. In reality I haven't driven more than a few hundred K's since it was installed. With some tuning I may be able to make it more acceptable to me.
More likely, I will put it back together, take it to Willowbank to set a time & then swap it to something like Dale's. I have my doubts that I can get it to a point where it will suit how I like to drive the car, but I'll see - eventually.
Ordered some new rims for bigbird. Got a crack in an existing weld on my enkei rim. Didn't even realise the rim had been welded.
New rims are Advanti Stage(a) Drift 17x9 +15 Tires still 235/45/17
post-58831-0-41266500-1343377014_thumb.jpg post-58831-0-18692400-1343376999_thumb.jpg post-58831-0-99514300-1343377006_thumb.jpg
Nice clearance to the coilovers now.
Also found these !
The guys at o1g are awesome
Fired my new engine package up for the first time. slight miss (over fuelling) need to have a play with the niss tune, and a oil leak from new oil cooler pressure sender. all in all very succsesful considering the loom modifications required to chuck the neo into a s1. as well as the fuel set up changes and manual conversion at the same time expected more hicups. was good to hear the nice lump of the pon cams ocasionally even through the miss lol. just need to bleed clutch up now sort a few more things out then some tune time. 6 months off the road is too long hanging out to drive the old girl. should only be a couple more weeks. Then i can feel like a stag owner again
Let me know how you go, and we can see if we can do a deal if it helps. Is it that bad? I'd imagine with the F-con I can tune any issues out.
Will do - maybe a swap of some sort could be on the cards? Not sure if tuning can totally eliminate lag. I suppose programable boost control can help somewhat, & supposedly retarding timing can also help. I should stop whinging about it, lol, & just get on with making it work.
Also, just because I think it's too laggy doesn't mean someone else won't be raving over it.
Must be time for a cruise then Jase! About time, needs more pics!
yeah i think we are all due for a stag cruise . not sure how to get pics up as i use my smart phone
for the net. might have to use image shack or something as it wont read pic files straight of my phone
got new tyres fitted today, bought some falken FK-452's.. hopefully they will be fairly grippy :D has a little issue going from 235 up to 245... 2 much low, camber in the ass was that bad, that the tyres were on the coilover spring perch haha, and i have 19x8.5 @ +12 offset if thats any indication of the camber haha.
You don't have too much camber - your wheels are too big. I run 3deg neg camber front and rear on 17x9 in rims with 255 40 17 tyres which gives me a better contact area and also lowers the cog c/w 19in rims:
and my cheapo track rims 17 x 8.5in on slicks:
what is your offset... those 17's are a shitload wider than mine, my wheels sit inside the guards, even with the car raised up....... and they are a +12 :S also, if your telling m, in that top pic you have 3 deg neg camber, i must have about 15 deg neg, because all my wear on the old tyres was only about 1.5 to 2" wide lol, rest of the tyre was new hahaha. my car has a takeros body kit, the side skirts are like a step they are that wide, the bottom of the tyre is inline with the kit, the top was atleast an inch in and under the guard, and almost on the spring perch... its was a bit ummm... unrealistic really, but fun to have it dumped for a while.. not very practical, i had to raise the coilovers 45mm in the rear to even get the top of the tyre close to flush with the guard :D as i said, fun for a while, although it was like driving a commodore lol, but it looks like a 4wd again now.
Edited by OMY31T
Last week had my driver side front repaired after an accident a few months ago and finally fitted some 18's to the car... she's now looking mint but needs to be dropped an inch still i recon.
Also pressed in some new Inner Lower control arm bushes the other day; mine weren't damaged, but the new ones look to be much stiffer.
This should help remove some deflection in the LCA, and still deliver good ride quality.
Also did an all over suspension bolt check; one of my rear links needed nipping up at the Swaybar.
If you have a chance, and have been doing any work on your suspension in the last month; get under and check; not just visually, with a spanner.
Cleaned out the AAC valve today. It's fixed an idle problem that I was having, and the car also feels like its revving a lot smoother.
Edited by 180fan
2 1/2" Suction pipe tacked together for a trial fit tomorrow, prior to purge welding.
Now we get to see how accurate my fab is. :whistling:
    • Go to SP mufflers and get the muffler of size you want and make a nice mid muffler. It's about that simple! I have 2x 3.5 Magnaflow straight through Mufflers and while it's pretty loud with the Varex open, it's quiet enough with the Varex closed. You can also buy off the shelf Magnaflow straight through mufflers as well. You also have a turbo to quiet the car down too. Don't overthink it. Buy my extra Magnaflow muffler sitting on a shelf doing nothing (buy it new, ignore this part)
    • Centre-offset muffler under the floor, same as stock. Just....3.5". The change from straight pipe there to centre-offset will mean that you need to remake some of the pipe (add a bend or two).
    • Hey guys. So my R34 GTT has a custom 3.5” exhaust (done by previous owner) with a high flowing cat, and then just a Varex cannon muffler on the back. The car does drone alot and is really loud even on highway driving just cruising, as you can imagine due to the Varex muffler basically being a straight through with the valve open. As much as i love a loud RB, it can be a bit much with no other muffling in line and just driving casually. I wanted to lower the volume output on the exhaust a bit, as well as remove the drone (probably a way to do both at once), and was going to do it all myself as I am a fabricator and have done exhaust work in the past, so the fab work isnt my issue, im just not sure on the right product or type of product to use to get the job done, and i doubt an exhaust shop would be wanting to help me as they wont be making any money from helping me, unless they supplied the product? Anyway any help or guidance in best way to approach this would be awesome   Thanks in advance
    • Meh, whilst the Honda is a "really" good car and has potential if you want to drop coin on, it was uninspiring for me to look at, but, it did serve its purpose and is now in the boys hands, his happy, his girl is happy, as she wasn't to keen on the noisy old Patrol, and most importantly, the Minister for War and Finances is extremely happy that her "little baby boy" (6'2 nugget who is currently training to be a copper, which will make 3 coppers in the immediate "circle of trust") has a well sorted reliable car that doesn't guzzle diesel Me, I'm more than happy with the NC MX5 that I replaced it with, it's a fun little car that I like looking at, like driving, and yes..... I do like the fact that the maintenance and modifications that I have done/will do are plentiful and relatively cheap, well........ while staying naturally aspirated slow that is, and that's all I really need for a fun little daily, I can rev the 5hit out of it rowing through the gears and never really break the speed limit  In saying that wicked word, "modifications", I've already ordered something for some noise and an additional "3 ish" horse powers, or whatever it gives, in the form of a header, and, a new set of "cheapo" BC coilovers that are already sitting in the shed waiting to get put in, I had the same BC's in my old NB and found they were fine for the street, hwy, and the occasional track days I did in it, they have 6kg front and 4kg rear springs which is about 10% stiffer than the stock springs which I found worked well for their price  I've also already been in touch with MX5 Mania in Dural, so once the header is on it will get a ECUTek RaceROM tune there (I cannot rev match for 5hit, and I loved the RaceROM rev match and FFS in my old 86 "RIP") In other, maintenance news, I put some new sparkler plugs in it, and have a new set of DBA Street series pads to put in over the next day or so, I'm running the DBA street series in the SS and Honda and really like them, they work great and are not dusty at all I've also booked in a few days leave over this weekend to give me 4 days weekend do some paint correction and give the leather seats some conditioning and interior some Bissell and steam cleaning OCD lovin', the carpet and interior looks clean, but from my experience with the Bissell IRT carpet, and the steam cleaner IRT trim, looks can be deceiving I've also found that finding a detachable hard top is proving problematic, the main reason why I didn't like the NC initially was the power retractable hard top that I seen them with gave the roof line a weird look, the detachable roof though looks good, and is a same shape as a NA/NB hard top, similar, but unfortunately not the same as it has different fixture point on the front, so fitting a easy to get NA/NB detachable hard top is no bueno New Old cars are fun, cleaning, hunting and playing around brings much joy How are your beasties going? Do you still have the Skyline with the LS???, or Barra??? that you were playing with
