my RS4s ECU decided to die on me the other day >_< mech said all the outputs are fried!!...
ended up finding a solution with a Series 2 Auto ECU he had laying around...
and now my car actually feels like its running better and smoother.. and no longer so rich... (it was running very rich lately)
trying to source another manual ECU at present via JDM..
is there any potential issues with running the auto ECU in my manual ?? Mech was very unsure if there would be ramifications.... :unsure:
If I can't find a reasonably priced manual ECU.. might just have to get myself a Vipec after I get my clutch done... *sigh* that time of the year I guess..
(thanks for the info Cam / Scotty)
yeah according to Mech the wiring was 'spaghetti'.. not sure what had been done previously in there, but its been sorted out apparently.... got a pretty hefty labour bill at the end of it though...
(and an empty tank for some reason :/ .. will have to question that one.. was 40km on the o.d.o since filling up)
and a $300 deposit on the auto ECU, (hence trying to find a manual one cheaper for the moment, then give it back)
Edited by atomaly
Tomas there is no problem or difference for running the auto ECU in manual. The auto has an additional function to cut timing when the gearbox says there is a shift taking place - but since there is no gearbox to send the signal that will never happen.
I ran an auto ECU in my manual for about 18 months until other mods meant I needed to go aftermarket.
Also, auto ecus will be everywhere....but manuals will be much rarer just like the donor cars
oh that's a relief :) .. I didn't modify my ECU, but then, I wouldn't know what's inside it.. I might go grab it now and open it up.. ... ok looks pretty stock.. no mods!
might just pick up a second hand auto ecu cheap, and give the other one back (as there is some issue with it which is why its his test one)!!
anyone got a spare S2 Auto ECU they'd like to part with ????? :D
I don't, but you should see them come up time to time, for about 1/10th what your tuner charged you. Make sure the part numbers match, there were smoe pinout/wiring differences in some of the models.
part number for mine is 23710 0V801 JECS TM
not sure what the Auto ECU number should be? does anyone have a list of which ones are compatible?
or at least how to tell which one is series 2.... did a quick search and can't seem to find much info.. (even looked through the stagea parts list thread)
Edited by atomaly
There are three different S1 ecus and thus three different looms. Earliest and most common is the OV300 followed by the OV301 and then the OV310
Series one are Hitachi Series 2 are Jecs. Some S2 ecus are OV810 and OV811
Grab this one really fast if its still available - fully tunable - worthwhile even on a stock motor!!! http://www.skylinesaustralia.com/forums/topic/407534-nistune-s2-rs4-neo/
I like what you're doin' there Leon.
Also, clear tube is for catch can?
Thanks Cam.
Yes, catch can under airbox. I just replaced the abomination of multi sized tubes that was my last effort. The clear will be decidedly brown in a few months, lol.
Thanks Cam.
Doesn't the clear tube to the catch can suck itself closed under idle vacuum? It gets pretty soft once the hose heats up
Not in this case because it isn't routed back to the plenum. After the catch can it goes into the intake before the turbo. At idle it is subject to atmospheric pressure only.
Just fitted Dale's Piano Brace. Awesome stuff.
Now just have to finish installing the wideband so I can put the dash back together.
I can't believe how long the 'piano' reference has hung around, lol.
Leon, do you have the PCV valve catch canned on the other rocker cover (assuming VQ25dets have the same PCV set up as VQ35des)?
Thats the one that would suck closed. I went and bought some heavy oil resistant pipe from pirtek for it. The one you have catch canned, and correctly I might add, required both vacuum and pressure. So it has to be able to suck in and blow out. I believe that the PCV is more important to catch can than the other side, because it has move vacuum drawing oily gas out and into the plenum. Thats how I thought it would work best anyway.
yeah, that's the one I have the catch can hooked up to - between the PCV & the plenum chamber just above the centre inlet runners
at idle it was sucking the hose closed so i ended up using some 3/8" brake booster hose which has enough reinforcement in it to stay open under vacuum
Yes & no. It is there but not hooked up. Everytime I connected the hose my old turbo would smoke because the seals were shot. It must have been adding pressure to the system. Maybe my PCV valve is stuffed, although it seemed to be doing it's job when I removed it to check. I have literally only just got my new turbo in (& now not leaking :) ) so I can connect the catch can again & see what happens. Hopefully my PCV doesn't allow boost into the engine & the pressure blows out something important...
Alex, I know you stuffed your can with steel wool. The theory is to filter the oil out of the air better, right? How long did it take to poke it in thru the drain hole?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
