I like your style. I want to fit an oil pressure/temp gauge somewhere, might try and move the DVD ROM, but I'm keeping the factory screen.
Picked the car up from AM Performance tonight. Andrew had pulled off the intake and traced the flange, so while he gets the flanges laser cut I get the car back so I can change the belts and do some other bits.
Was good to get it back and go for a proper drive, when I wasn't in as big a hurry as when I drove it there. Only the second time I'd driven it since the EVC6 went in.
Obviously there are still a few things to sort out with the EVC.
Firstly, I noticed the settings had zeroed out. I reset it all, and then noticed that every time the ignition is switched off it wipes the settings. I'll download the PowerWriter software too, and see if I can work out a decent solution.
Second, once setup for 15PSI peak/optimum boost, I notice it now makes 1PSI at ~1500rpm according to the EVC display. Boost feels like it comes on a lot stronger, and it feels much nicer to drive, especially higher in the rev range.
Thirdly, since I run a pod and the Turbosmart dual port blow off valve (plumbed back and adjusted properly), I've had some chirping and turbo noise which is apparently not a good thing. I spoke to Turbosmart and they blamed it on the pod, not the spring or anything else setup wise. I notice since the EVC went in this is virtually eliminated.
So all in all, very happy with the HKS EVC6, and once it's setup properly should be an awesome addition. Car certainly feels sluggish on the default 11PSI though!
I considered moving the DVD rom first up, but the cables to the back of it were so short, the only place you could really tuck it away is right where the passenger airbag sits. There's just no room under the dash without taking something else out & I wouldn't like the thought of cutting & extending the leads to somewhere else either, they look like they'd be pretty easy to screw up.
I want too concerned about losing the factory screen capabilities (mine was even converted to English when I got it) - mainly because I had already lined up the Alpine 2din
Your android tablet gauge pod is awesome.
Clean, no clutter, no tackyness... just smooth...
C34s wouldnt have a compliant OBD for that kind of multimonitor thingswoud they?
I had a look at a few ebay head up displays but wasnt certain if it would work and be configurable enough to give me:
A) RPM graph
B) dig speed
C) dig boost
Thats it, no other shit on my windscreen.
dig water temp would be nice.
Edited by shane344
A) RPM graph
B) dig speed
C) dig boost
The info is all interpreted through the OBD port by the HKS OB-Link, which is plugged into the car & sends the info to the android tablet (or phone) which is read & displayed by the corresponding app.
HKS have a list of compatible vehicles that the OB-Link works on, not sure if the C34 is on there or not...
The OB-Link cost me about $230 from Greenline
Took Moby for a drive, and filled up the tank.
Got the EVC setup. I really should learn to read instructions and push the combination to write the settings to the ROM.
It's now setup for normal boost at 15PSI and max boost at 15.5PSI. I don't want to go any higher than that on the stock turbo, lest it blow apart.
It feels brilliant from 1500rpm now, really pulls and goes, which makes the throttle restriction worse... Good thing it'll be leaving soon! :D
The turbo is making far fewer weird noises now, less 'helicopter' noises, less sneezing. It feels like it's either on, or off, with no slur in between.
I like it!
Found a standard 260RS front bar. It's months away from getting to me but i'll respraying the front end and touching up the rest of the car when it finaly get here.
Anyone keen on a genuine Freeway Dolphin front bar?
Pretty Sure its only the 35's that have this OBD2 port. 34's use the older OBD1.
Also did this to my stagea yesterday
drove over a roofing screw :verymad:
Edited by Nadnerb
Replaced the accessories and air con belts with new Gates Micro V belts according to Cam's helpful tutorial: http://m35stagea.info/forum/viewtopic.php?f=6&t=88&p=1867&hilit=belt#p1867
Used the same part numbers as Andy. Was pretty easy.
There is some squealing on startup now which goes away very quickly. I think the bracket for the tensioner on the aircon belt is cactus though, looks bent, so may need to replace this depending on how it goes.
Also thought it was interesting that Gates' instructions recommend replacing the tensioners with the belt - has anyone ever done this?
Also didn't bother putting the undertray back on. Looks pretty sad and sorry for itself. Think we need to look into getting something like this made locally:
Is this something AM Performance could knock up?
Possibly, otherwise I know dad used a local sheet metal mob to do some work on his rally car, might be worth chasing down.
For it to be worth making locally it'd need to be less than $200 each, since you can get them for ~US$170 plus shipping.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
