rear pads in, hopefully gotten rid of the wear issue i have been having, right hand pins/sliders were seized, so relubed that up and seems to be working better now. could actually slide by hand when i was done.
Got the HDI FMIC on yesterday, not too bad. I need to sort some broken/ missing/ torn out undertray bolts asap. I have the NUR catback exhaust and Scotty's dump and front pipe on it already. I think the next thing is Dales induction tube and a high flow turbo. But which one ? What I want is a quick road car not a race car I can nurse around the street, and the numbers are less important than the feel and driveability. But I'd love to try before I buy. :unsure:
I have the kits that Commsman uses to tweak the computer but haven't had a chance to solder them up. (Before anyone jumps on this I have been working overseas from 2/12/12 till yesterday.) (And I have not had the car tuned yet. :yucky: )
Hi Leigh. Give me a while & I may have a hi-flow you can try. But I wouldn't rush to change the standard turbo out, unless it's had it.
+1 with Leaon about the turbo.
If you do the Banjo mod and keep good oil in your car the stock turbo can perform very well and is hard to beat for off the line drivability.
OK Thanks for the offer Leon and all the great help, assistance and advice you have given me so far. I love my sound system/media system. The cruise is absolutely necessary and even the wheel switches started lighting up since we did the slimline fan in the FMIC install! Go figure! :wacko: As it gets quicker it gets harder to set the cruise to avoid it hunting but that's expected at some level as the turbo spools. Just went down town through a 50 zone and watched the car burble up a rise at 900 rpm/50 kph in top gear! Gotta love that... When I said that I wanted to try before I buy ... I meant experience what other turbos respond like, not necessarily from a drivers seat. A seat of pants from a back seat where I can see the rpm, roadspeed and feel the response should give me a clear idea if it is too laggy for my taste. This car will never be raced, if it does go down a drag strip that will be the exception rather than the rule. The problem is trying to find the balance between driveability and power. As I do not want an extreme car some of the more prominent peoples experience is irrelevant. It is probably true that the people I really want to connect to do not post overly much. So if you are out there and have a moderate highflow and induction solution with great driveability and reasonable performance at a realistic price please respond! My standard turbo is OK atm so I am not under any pressure at this time. :closedeyes:
i'm pretty sure someone is rebuilding the turbo basically to stock spec's might have to ask Jet_Wreck about it.........
hi Andy long time no speak, what's the banjo mod?
That's where you drill out the turbo oil feed line at the banjo bolt. It is a really small hole that can get blocked by grunge, especially if service intervals were 'stretched' when back in the mother land.
It is widely believed that Aaron's turbo failed due to this oil line being blocked.
Looks like he thinks Craig's advice is irrelevant, it's the reason I never posted a response anyway.
cheers Leon. :)
Replaced my broken cibie light glass.
Cleaned up ok Josh?
Looks like he wants something he can drop in without tuning etc, and doesn't want the power some guys are making. I get that.
I don't think Craigs' recent thoughts are common knowledge, ie he wouldn't know if irrelevant or not. And, as it turns out, is very relevant.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
