Bought e-manage ultimate, 14point7 wideband o2 sensor and boost solenoid.......................first mods ahoy captain!
Good choice :thumbsup:
I'm going to use the extra injection channel to control a mac boost solenoid to see if i can smooth that rubber band a little. Will log afrs for a while to see if i can trim fuel and increase efficiency and therefore powahs a little. I have no intention of going near timing as i have no knock sensor. have got a MAP sensor to hookup as well. Im not going to go crazy but how many in here have said that?
Not much point trying to adjust fuel trims unless you ditch the stock narrowband, which would probably be detrimental to fuel economy. Plus, leaning the fuel on cruise would make exhaust temps skyrocket.
The stock computer does a pretty good job actually, the Emanage comes into play when the AFM voltage is maxed, and you get shot through the windscreen on fuel cut.
Lol, I was talking about Craigs mess but as you saw Leon, it doesn't take much.
Considering it's an engine transplant if you don't have fuelling spot on, and aftermarket engine rebuild parts are non existent, it could get expensive.
Aint that the truth :/ .
Jealous low blow Scott!
Just because you have no wing!
I can now hang out with EVO-Tards!
P.S. Where's my front Bar Theo! :P
I can't see it... Needs to be painted another color to stand out...
Orange perhaps?
Is it tech screwed down?
Double sided tape. Wing holds itself down.
Finally removed the small bracket under the car that had been banging against the coupe mid pipe since I fitted it... Think it was there to catch a broken tailshaft...
15 minutes I should have invested months ago... No more banging from under the car.... :yes:
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
