I have a few but none fit down (or up) there properly. I can do it in a minute or two now with my cut down 22mm open end spanner though.
I fitted Whiteline diff bushes in my car today, quite cheap to buy too. It made one hell of a difference too, all the axle tramp is gone and it chirps nicely between gears again, it really tightened the whole back end. My original rear diff bush was totally flogged and was leaking oil.
well on the bright side it will be a good test of banjo sizing.
symptom 1 of too much oil to the turbo will be burning oil at full boost (grey/white smoke)
symptom 2 of too much oil to the turbo is the turbo seal blowing.
If neither of those happen, it's not too large :)
  • Like 1
The stock Garrett core will have a restrictor built in so it shouldn't pose too much risk, that said the VQ runs stupidly high oil pressure, I have seen 10 bar on my gauge which I think is it's limit...
I wonder if that had something to do with my issue? Stao told me to drill mine to 4mm.
That seems very large. I did mine with 3mm (think that is what is was, was more like find drill bit to drill after 10 hours under the car changing turbo).
I agree with scott, 2.5mm max.
John from Precision recommended I drill mine to 4mm; so I did. No issues with mine.
Oh joy. Replaced another AFM.
FML.
I popped my new genuine Nissan one after about a month; failed just as the car started.
I bought a WRX one the 2nd time. It seems to be going fine.
It fits about 4 billion different models, so at least they're easy to get.
What number are you on now? I think I've killed 3 now.
Did you buy new last time, should be under warranty surely.
This is the 2nd one thats died in 4 months.
Got a 2nd hand one last time from a wreckers which they gave me 3 months warranty on - failed after 4 months to the day. lol
Today Craig and I, well lets be honest mostly just Craig fitted the plenum spacer, scotty's coolant mod, transgo shift kit and finally got around to doing the fun switch mod.
Improvements?
Shifting is definitely faster and I actually think smoother. I havent driven it alot yet but we stalled it up and even with the fun switch off the boost is coming on much stronger. Will see how it goes after I drive it a bit. Still have a random stalling issue but hopefully will get that sorted soon. The car is getting there :)
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
