The undertray creates a low pressure area in the engine bay, which radically improves airflow through the rad and clears excess heat from the engine bay.
It may not make a noticeable right now; but come summer, it will.
What about the little one that covers the power steering etc?
That's nice to know Dale. Cheers for the information, but there's still the problem of lazy, hard problem to solve aswell :P.
Not as much; it's mainly there to protect against things like rocks or sticks flicking up & damaging things.
That's right! lop that shit off! I had no choice with my under tray as it was rat shit.
I think there is reason for you to develop a front undertray that is more efficient and avaliable for sale in a group buy
Only 1/4 stagea soon to be full half stagea.
I havent really done anything just bought stuff.
-VQ25DET
-Turbo
-Dump
Waiting for the tax man to hurry up so i can buy E-manage.
Scotty and i have spoken about that a while back,i might have a chat with him once i have the other little bits and pieces soughed out.
My undertray is gone aswell. But i have seen the rareJDMs ones on ebay and the ones made by tollbothwilly for G35s.
Having just got rid of the sedan undertray with a stagea nose they are similar but the stagea has a short front overhang.
But if someone wants to make up a template of the stagea undertray out of cardboard i can contact tollbothwilley and as him how much it would be if a few of us got behind it
After all the discussion on it, I got motivated to fix my under-tray after it did its best to come off on my trip across the nullabor. Also went to get tyres yesterday. Bought the tyres, but also picked up something else...
Emanage Ultimate arrived monday, HDI intercooler should arrive before friday, have a 260 nismo dash sitting in my lounge room and a Greddy boost controller somewhere in garage...
At some point i'll get time to start fitting things before i order more parts
Oh no!!! You bought a Corolla!!!
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
