S1 Dayz.
Pic of the freshly painted brakes, because I just worked out that I can attach files using an iPad (yeah, yeah: I'm a slow adopter...)
Still have to tidy up around the engine bay: that wiring is embarassing... but you get the idea.post-39451-0-64102700-1377560237_thumb.jpgpost-39451-0-92587600-1377560277_thumb.jpg
Just received my Synx 6000, LS90 (diff oil) and bought some semi-syn gearbox oil the other day
Time for some loving for the stag
Oh, and polished the bonnet and roof the other day
My qutar window vents [what i guess you call them] started to flake so i decided rather then risk breaking them by pulling them of to respray i would cheat and plasti dip them insted [also alot cheaper seeing as i had left over and easier]
 *snip*
Hahaha every time i come into this thread i see one of my next mods all listed out.
I was going to do this exact same thing; also on silver stag...
:lol:
Hahaha every time i come into this thread i see one of my next mods all listed out.I was going to do this exact same thing; also on silver stag...:lol:
Twins...lol
  • Like 1
I think 13kms out of a rebuild is a good enough reason to look for a different engine builder. id expect a free rebuild on the 2nd one for that effort.
6th booking part one: never actually made it onto the dyno due to bottom end knock: engine had spun a bearing 13km after rebuild
S1 Dayz.
Still have to tidy up around the engine bay: that wiring is embarassing... but you get the idea.attachicon.gifimage.jpgattachicon.gifimage.jpg
I have been trying to figure out how to do this but can't get anywhere ( attach photos ) how did you do it.
...And that's exactly how it panned out...
Have to use the full site, then go to "more reply options", and you can attach from camera roll.
no idea if it works from iphone: too pokey, so I cbf trying.
Synx 6000 in - happy days
2+ hours rolling around the floor only to undo one fill plug for the rear diff - sad panda
who decided to make gearboxes and diffs so shit to put oil into?!?!
I think i'll pay someone to do this job
oh, and one of my headlights is out :(
fingers crossed it just the bulb
anyone have the link to the place selling the philips bulbs for a reasonable price?
On my M35, it's easy :w00t:
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
