that's about the standard boost mate....is the boost controller turned on? generally it would be set between 12 and 14psi for a standard turbo :teehee:
oh really? I was told by a few people that standard they are meant to be set at about 7psi and 10psi is the 'safe' boost to run daily on stock turbo. Boost controller is turned on, but i haven't tried playing with it yet. Need to download and read the manual :/
Blowoff valve and wiring loom for ignition coils arrived today! Wuhoo! Off to mech on Friday to have it all fitted up, then as soon as my tuner has time, we'll give it the 5th "final tune", and everything will be awesome (probably wishful thinking given the epic issues, but you gotta stay positive, yeah?)...
Sounds like it should all be sorted :) it's good you got back on the horse, it can be really detering when these things happen.
I remember someone asking for a picture of my seat because we were bidding against each other months ago. So here it is.
Wow cool seat!
Update on our stag. We put a new fuel pump in (walbro) then started getting a hesitation on take off and light throttle. Checked voltage at the pump on idle and revs. 9 volts!! Haha didn't really want to run a new power cable etc so at first I was like il try earthing the fuel pump direct to the chassis and see what happens.
So did that and check voltage. 12.2 volts. Sweet! Went for a drive and the hesitation was gone!! Yay
Car went on the dyno again and made 180kws at all four wheels. Goes much harder now, wow haha
good to hear that it was a simple fix, but you need to be a little careful with just putting it straight to the chassis. Does the fuel pump still turn off after a few seconds when you turn the ignition on (but do not start the car?)
In a lot of these systems the ECU uses the earth to turn off the fuel pump when the ignition is on but the car does not start.
If your fuel pump does not turn off (may be hard to hear), you need to add a relay where pin 85 goes to the original ECU earth to the fuel pump (12v can come from any ignition switched source to pin 86). Then connect the old fuel pump earth to pin 30 and pin 87 then to the chassis earth.
What have I done to my Stagea lately??
Nipped in to town to do some shopping!
All this gear in the car and still could of beat any Commondore!!!
Sent from my HTC One XL using Tapatalk 2
hay
What have I done to my Stagea lately?? Nipped in to town to do some shopping! All this gear in the car and still could of beat any Commondore!!! Sent from my HTC One XL using Tapatalk 2
That's quite a bit of stuff is that shopping for a couple of months!
Gktech open ended wheel nuts on order, once they arrive I'll start playing with my spacers :-)
Managed to pick up two pairs of their 15-30mm spacers for $150
Should be able to fit my kakimotos over the front brakes now
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
