Is that figure per strut?
That was for the pair
Did you remove & check the ball ends on the body when the struts were out?
About 2 weeks after I had mine regassed I snapped one off.
Very annoying.
I didn't remove them, did look them over and they looked to be in good nick.
The strut guy actually refitted them to ensure they'd have sufficient force to hold the boot & raise it easily. Oddly enough, he'd done a few M35s and said that each of them had different pressure ratings on the struts, not vastly different - always north of 1000nm.
You won't see a potentially damaged one; they snap the threaded shaft about halfway down, leaving 10mm of thread in the car body. It can also scar the paint on the inside of the C pillar and roof edge if you're really unlucky. I was incredibly lucky not to damage the paint when mine broke.
Support the hatch, pop the struts off, and remove the ball ends. Check the threaded shank for cracking; and remove the rubber washers (if fitted).
If they're undamaged, you've only wasted 20 mins. It took me twice that to get the broken piece out of mine.
One of mine snapped and damaged the roof as I closed the rear door. The other side snapped as I undid it to replace the ball.
Ouch! Will check them out over the weekend then, good tip Scotty & Dale! :cheers:
  • Like 1
Fitted a walbro today and gave her a service.
Also booked it in to finally get the adaptronic and tune done. 25th of august can't come soon enough
Did you run the relay and fuse back to the battery mate?
I didn't really proof read my question...just to clarify, I meant are your struts 1200nm per strut?
Love Bluetooth in the car. CCS did the work?
Thinking about using them for a new alarm; they seem very thorough.
Yep, I did go through CCS - they're not far from home for me either, which helps!
i've been really busy with my stagea lately, i changed my rear subframe.
S14 subframe fits in good, got all adjustable arms in the rear now.
changed the rear wheel bearings too. rolled my guards aswell. :happy:
Last couple of weeks installed new upper rear ajustsble control arms, new bushes for rear sway bar , new front sway bar bushes, and a new battery on Thursday, got one of those new green battery's from battery world
Going to tackle cleaning my coils and putting electro paste on them to see if I can resolve my miss around the 5k rpm mark
Edited by poohkies
well fitted the Cusco brake stopper on the 260rs and it really improved the braking response. Definitely best mod and easiest for improving brakes!
Have you done brake lines as we'll? Very interested in doing this
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
