I got the HKS Silent Hi-Power exhaust fitted today at Hills Motorsports. Probably a good thing I paid to get it put in as some bolts were quite stuck, to be expected on a 16 year old factory exhaust.
Sounds great around about 3-4000 RPM, very quiet on idle compared to the factory system.
Finally reunited with mine last Tuesday after 2 months off the road.
Now sporting a rebuilt transmission from Kewish. Never realised how much I enjoyed my until I had to drive a 2" raised Prado for a couple of months (good car, but that handling :()
What happened to box?
Hit a 'roo.
Impact caused leak in lines which I couldn't see, being just after 1am.
Got home, no fluid in box.
Much better now though.
Downside is that it also tore apart the harness leading to the EGR sensors.
Wiring was worked on but still get engine light so may need a replacement harness... too bad it is the same harness that runs along the top of the engine :(
Edited by iamhe77
  • Like 1
S So after a few years of purchasing the bmc g35 cover I have finally made the effore of making securing brackets. All thats left to do is paint them black and source some black pop rivits to finish it off.
Edited by joshm35
Lakes101 awesome work mate!!!!
Love the strut brace? where can I get one from for the Axis?
Love the catch can mounting, interesting location thats for sure.
Regarding the cooler install, how much of the reo bar did you have to chop out and mod?
  • Like 1
There is no chopping or modding required with the Hdi front mount.
Hi Guys!
I thought you might be interested to see what I've been doing to my Stagea in the UK. I know Stageas are big in Oz but we have quite a good scene here and I'm aiming to build one of the best:
Here she is, just back from the bodyshop:
That's 19x12" rears with 355 tyres BTW!
  • Like 2
cheers mate. The strut brace is a g35 one from the U.S. Can't remember where I got it from most likely conceptz
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
