Got my front windows tinted the other day to match the rear windows and while they where at it i got them to Tint both my Sunroof's
Couldn't find much on other Stagea's getting their Sunroof's tinted, so just went ahead and got it done.
They used 5% Silver finish tint that normally goes on house windows to reflect as much heat as possible
Pretty happy with it!
Graeme got a side on pic of your car? Are those rear guards steel or fiberglass?
Yes, here you are:
And here's a close up of the rear spoiler, which is another aspect that I'm really pleased with the way it's come out:
The rear arches (or guards) are fibreglass on the door and steel on the main body.
  • Like 2
Just ordered some RDA7701 3224mm GTR rotors and dogbones. Going to run Project Mu NS Pads
Anyone running 324mm with the sumitomo caliper + dogbone?
Are you running GTR Brembo with stock brake master cylinder?
Stock master is fine with them.
I have r34gtt brakes with 5000k old pads and rotors for sale. Direct bolt on, 4pot caliper, huge improvement to the dodgy stagea brakes. And heaps lighter! 500 bucks.
Lookin good Zach. :)
Message me when you are doing the dump install, it's a pita but if you follow a few simple steps you shouldn't have too many dramas.
Also make sure the car is stone cold (overnight) and soak the studs in WD40 for at least a few hours.
  • Like 1
Custom plenum inlet pipe?
Looks better than the ones I made back in the day, using an evo Kompact BOV by the looks of it rather than the Nissan flange. Simple and well designed.
  • Like 1
Yeah looks tops, super clean almost stock looking
But is it lobster back....
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
