Swapped out my factory auto craddle for a manual r34 item and some axles. Fitted some tyres to my varrstoen es3 and had a wheel alignment. Then took her out for a play at the drags. Ran through at 13.8 which isn't bad for open diff and the attesa needs to be bled still.
  • Like 2
Finally picked up the R35 GTR seats.
They are in really good nick so i am pretty happy.
Black with black stitching so they don't have the stupid red inserts.
Next comes the job to get them fitted to the M35 :yes:
  • Like 4
LIKE!!!
One day I would like to do the same
Changed the o2 sensor in the m35 today. For anyone interested you can do this from above. I have included a few pics to show the access, first picture is how it looks from above. Second is with the stupid bracket removed which I should have done straight away. Third is the combination of sockets and extenders I used. 4th picture is for part number reference
New sensor was $125 Inc shipping from amayama
Pls report back saying it was really easy and quick kthx.
Finally got around to rotors and pads.
To: DBA T2 rotors and 370z Nismo pads
Very, very happy.
See, now that's just lovely.
Edited by iamhe77
Part numbers and pics cam?
Front rotors - DBA2314S
Rear rotors - DBA2315S
Front pads - D1060-1EA01
Rear pads - D4060-1EA01
Rotors purchased through GSL/Brakes Direct and pads from the US (conversion inc shipping was cheaper than the shelf price in Japan oddly)
Dunno why the interest in pics, but here you go Josh.
A pic of a dirty wheel in a poorly lit garage :P
  • Like 1
Looks awesome ! still running AWD or just rear wheel drive?
-oliveR that looks really nice man, good fitment, but what was the reason for different profiles and width if you don't mind sharing? RWD I'm guessing also?
It's an AWD, the difference in the rolling diameter is under 2% and haven't had any issues with the Atessa so far.
Went different width and profile because I wanted similar sidewall look front and back rather than having one flat and one slightly stretched.
  • Like 3
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
