Got myself a factory spoiler off Yahoo Japan. I'll have to change the shape of my "fast groceries" sticker now!
Looks great!
What did it end up costing you to get bit here, if you don't mind me asking?
Looks great!
$400 delivered. (Have seen them go for cheaper in black, silver or white but was happy to pay a bit more to get the factory paint match)
I needed a third roof rack to carry long timbers for work but fitted a cheap wing instead.
Three racks would look crap,plus no where to mount it unless I drill the roof., quite happy with this.
I velcro a sponge roller onto it
Had to spread the mounts right to the ends, then drilled right through the plastic cover trims and hatch to bolt through.
Drill holes are in the drain void too.
Huge difference at 100 km/h, the cars feels way more planted.
Naturally anodised aluminium matches the Whisbars.
just bidded a set of ZOOM brand lower springs from Yahoo JP and waiting for shipment.
during waiting, I just got time to take some photos for my lady.
nice wheels ;)
feel like making some more champ?
I don't feel the quality of my install would be up to sale standards lol, also if one of the 200 odd leds blows on the ring/s it will look poos as i, i can make a guide on how to do it if anyone wanted to give it a go
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
