Put 79.48 litres of fuel in my tank.
That's a new record.
I would've started looking for a leak when it hit 70! Good one.
Ordered premium plates just for cosmetic reasons. South Australia premium plates look much better on Jap cars if you use a large rear (on the rear) + a normal rear (on the front).
I've also saved probably twice as much cash as i need to look at better tuning for the M35 plus i'm still holding onto the Manual dream.
I've got the larger plate on the front and rear, I think it looks okay - it admittedly came that way from the previous owner but I never even contemplated getting a standard front.
What are you thinking in terms of tuning options next?
Today replaced a cracked LH rear rotor and dogbone that had a broken bolt in it. Got the bitz from the Dayz.
I need the parts back so if anyone has bits please PM or 0439100207
How did you manage to crack a rotor?
  • Like 1
what are you running the dogbones for are you using different calipers on the rear? Edited by Lakes101
Still planning at this stage as i've been fair busy of late... i always tend to be able to save a lot of cash when i'm busy with stuff.
It will have to be something stand alone (Haltech or whatever) but i am trying to get time to speak with local tuners. I'll see what sort of power it makes with my current set up and then i may have a look at any advancements in Hypergear units since the original SS2. this car is my daily so i'm looking for a nice balance between peak and response (i'm quite happy with the SS2 so it may make no sense to change anything)
In my opinion the dream is to go manual with some form of stand alone tuning option which i'm trying to optimistic and make forward steps. I've saved up easily enough $$$$ to do the job it's just not so easy getting things off the ground.
Once i have something to share i'll most certainly do so...
  • Like 1
Dont know. I think it got metal to metal and over heated The crack is radial on both sides.. But have no idea how the fixing bolt sheared. It appears to be an old break
Edited by 66yostagea
Changed the front struts. Holy crap the springs in these are solid, I destroyed a set of compressors on them, and even the large press at the local suspension shop was creaking a bit.
I didn't follow any specific guide to get them out, I have a Haynes manual for 350Z/G35 which was only handy for torque values since, well, it's a Haynes manual. To get the assembly out I removed the curved steel link (technical term ahoy!) that runs from the LCA to the bottom of the strut. Should the nut at the LCA end be loctited on? It runs through a bush and was pretty tough to crack. It also looks like the nut holding the brake line to the strut had some kind on loctite on it too, which seems like overkill for the job.
Also I really, really enjoyed trying to get to the left-side innermost strut mount bolt, thoughtfully positioned beneath two A/C pipes and two wiring conduits. Much swearing ensued.
  • Like 2
Recently installed the following on my RS4S:
Cusco Castor Rods
Cusco Front Upper Camber Arms
Hardrace Rear Upper Camber Arms
Enkei RPF1 18x9.5+15
Went to see Brian (ex Group A suspension Engineer) for an alignment which he runs out of his garage
FL Camber: -2.2
FR Camber: -2.0
FL Caster: 5.5
FR Caster: 5.25
RL Camber: -1
RR Camber: -1
Rear Toe: 1mm Toe in
Track = even
Car feels great! Massive improvement in handling, plow under steer has gone and turn in has improved dramatically!
http://www.gumtree.com.au/s-ad/noble-park/wheels-tyres-rims/work-meister-s1-3piece-for-swaps-or-sale-/1083914512
Why do you tempt me so gumtree!!!
WHY!!!
(anyone live near Greater Dandenong that can inspect for me????? :P )
Edited by Beregron
WHY!!!
Actually these are staggered.... Altessa won't enjoy that i assume :(
As long as your tyre size is the same it will be fine
Thats rolling diameter yeah... width makes no difference? (why would it....)
I just need to double check that offset for an M35. 10's on the back would require some guard rolling i assume but thats easy
In other news my M35 will be up on the hoist today with a mate who i am annoying (maybe a little too much) to get his head around manual conversion ideas. I have read about it more times than i can count on various SAU threads but action needs to be taken. Measurements need to be looked at i guess and while people say what will fit and what to use it all needs to be confirmed before i throw any $$$ down.
Then will come the tuning headaches...
Edited by Beregron
OK so a bit for forum trolling tells me that 9.5 +30 should only require slight guard rolling on an M35 and the fronts i'm looking at are 9 +33 so should be ok....
Rears are 10 +18 which is a heap of dish so perhaps that's where the problems will be... i need to find something to test fit that's similar
Hmmmm...
Lets see...
Rear adjustable camber arms, coilovers, wheel alignment, HKS exhaust, luggage lamp, and getting detailed tomorrow before the SAU QLD charity cruise.
  • Like 1
Just LPG'd my C34.
Long process involved which started back in September last year.
Long story short:
Stock fuel tank removed. Spare wheel well cut out. Boot floor welded flat. Fit replacement 32 litre alloy fuel tank, with in tank Walbro fuel pump. Fit external mounted 85 litre LPG tank to underside of boot floor. Run car like this for 6 months with a noisy Walbro. I need to get into the tank and fit some baffling around the pump.
Fitted the LPG kit a few weeks ago. My installer struggled to get the plenum off but managed to get it eventually. Looks untidy, but hey the rest of the car isnt much to look at either! Said he would never take on another Stagea install again!
Anyway, LPG is in and running. Managed to get the equivalent of 42mpg from the first fill up. For the AUS guys, super unleaded (97-99 RON) here is around £1.30p, I'm paying £0.43p for LPG! Since then one (or two) of the injectors have failed and are stuck permanently open. Likely due to the injectors being in crappy storage conditions for 18 months after I ripped it from my old Legnum. Need to replace the faulty ones next week along with changing the throttle body.
Then to tackle the wing mirror rust in August, and get the strut tower tops welded as there is some rust coming through.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
