They came up well!
thanks!
damn hard work on the hands sanding.. but so satisfying when done.
Took a while as I only have cordless drills so very low speed/ torque. For about 30 bucks in materials though a new lease of life
Found this thing waiting for me when I got off work today, freshly delivered from Sendai, Japan
btw anyone have access to the Nissan Fast software to run the VIN for me? Just want to be extra sure I did in fact buy an Autech 260rs, all the signs point to that but just want to be 1000% sure
  • Like 3
ahh they are such a great car aren't they :) post up or pm me the vin and i can check.
I used the Stagea to tow the Leaf to Bathurst and back on the weekend, it made easy work of a very heavy load as always. Very happy with how the car runs, even though it has over 300,000klm on it now
Big thanks to Duncan for running the VIN for me :)
Stopped by the local Super Autobacs yesterday after work and picked up a mount to hold my phone so I can use it as a navigation and picked up some good ol' JDM squash air freshener.
Phone mount on the left side, obviously no phone in it because I used it to take the pic :P
and some cheeky seat belt covers that I've had in every car since I was 16, they were a gift from a friend in high school for my 16th birthday
  • Like 1
Seemed to have developed a boost or fuel cut on hard acceleration in 2nd gear and sometimes 3rd. Not sure if what has happened but feel like the engine fuel and boost all cut for a second so I let off the gas for a sec and bang all good again. Any one with thoughts on what it could be boost cut, fuel cut ? Running 19psi on max rom tuned with Walbro pump 3" turbo back and intake.
Maxing injectors maybe?
don't know if you are running with EBC. if you have EBC, you can block stock boost sensor that could let you know it is boost cut or fuel cut.
with aftermarket ECU, maybe the problem is your 3" turbo back, it will increase your boost level.
btw, do you have boost gauge to measure the boost level?
i also have some fuel cut and EMU is on my hand now :nyaanyaa:
I have a ebc and gauge reading 19psi max boost. I deleted the stock boost solenoid a year ago. How can you tell if it's boost or fuel cut by blocking the solenoid?
You can just block stock boost sensor, then you never get 21psi boost cut.
See attached pic, No.1 is boost sensor
Could the factory ecu re learn itself and try to adjust for the max rom
It does exactly that, although it is fast at learning, so I would have expected it to be sorted on the dyno.
If the AFM is hitting over voltage in one particular cell it will fuel cut like this, but the voltage this happens at changes depending on the cell.
Nathan, if it is boost cut I would expect the MIL to light up. I wonder if the AFM was clamped correctly... As I said I have no idea how they tuned the HDI mate.
thank you gents I blocked off the map sensor this morning drove it hard to work to see if any boost cut... Seems to have done the trick.
I wasn't getting a mil light when it was happening but seems good now I'll test over the coming days and see how it goes.
I wasn't getting any cut in the dyno or for a few weeks after the tune, just came on all of a sudden. The ECU does learn at a fast rate so not sure why or how it happened.
Thanks for everyone's help with this gents [emoji106][emoji4]
  • Like 1
Some new wheels on won on auction so will have to wait for them to get delivered.
Also bought a Transgo shift kit to liven up the gear box.
The guy i bought it from has only one left. $250 + delivery.
If anyone is interested, please let me know so can pass the details on ☺️
This learning only happens off boost/low load for fuel.
Finally got my AMPerformance intake fitted, straight away noticed the extra flow.
Throttle more sensitive down low, less throttle needed to get the car rolling.
Haven't tested high rpm yet.
Thanks to Craig for fitting it, wasn't easy.
  • Like 2
Nice, and it's up high that it's makes the most difference
spent some time this weekend exploring, trying to figure out what mods were already on the car, so far I've found:
Nismo Exhaust
Nismo Air Intake
HKS EVC 3
Apexi Turbo Timer
Coilovers (brand unknown)
Carrozzeria head unit
waiting to hear back from local shop about doing a full fluid change/flush and to have them inspect the car in more detail
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
