C34 is 14mm. Not sure about M35. But you really you have at least a set of spanners if you own a car
Thanks for the info!
Yeah I really do need to get a set, haven't really needed any since I moved to Japan
went ahead and ordered a set from KTC
https://translate.google.com/translate?sl=ja&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.kpt.co.jp%2Fdetail_1.aspx%3FGId%3D14188%26MId%3D161%26FId%3D4%26SId%3D19%26TId%3D68%26FthId%3D194&edit-text=
installed bonnet damper kit today. it is for 350z but could be fitted on m35.
need to drill a hole on each side of fender due to m35 doesn't has it as stock (350z should have the hole as stock)
need 2 medium length bolts and nuts also.
open to stock height
happy with $60 delivery :rolleyes::rolleyes:
Looks like a handly little mod, interesting silicone hose layouts/ colour choice there mate!
that's BOV return hose. my bad i make wrong length when buy it... i re-ordered the customized one for 75cm long to make it beauty.
the hose is reinforced silicone hose, good for intercooler
Edited by YangLIU
Put some fresh front pads in yesterday, and chucked in some new plugs in at the same time.
Spent the first half of today chasing down vacuum leaks -.-
Still running like shit. Feel like I've done something daft somewhere/split something without realizing
Spent the last couple of weekends prototyping a rail delete kit. Covers bolt in place of the rails and have (printed) gaskets to keep the water out.
The covers don't look as good as a full patch job and respray obviously, but I like the fact that its reversible if I ever need to put the rails back on.
Cheers
  • Like 4
Link? Did you get my PM?
Cheers
That's a good job!
Hunting down a intermittent engine light issue. I have narrowed it down to something in the dash or the actual dash. Iv pulled everything out and cleaned jiggled wires. Just a question for those in the know, what is the black box with all the wires that is on the right hand side of the dash hole?
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
