  • 1 month later...
Rust be gone!  Except they keep finding more 🙃.    It's all getting done properly, cutting out and welding in metal, no cover ups here.  They normally work on Fiats and Alfa's, so they know rust 😆
After 10 years on the street. It will have an easy life in a dry garage.  I only have on street parking but I've found a lockup 10 mins walk away at very reasonable price.
Had an exiting run against a road bike, dumped it hard into 3rd gear as I pulled away & bang. I now have lots of little bits of 3rd gear, so I've done something to my Stagea but its not an improvement. Now I have a choice, a brand new 5 speed Nissan box for $3400 or a PPG dog box for $12000. Any suggestions?
lol, not ideal as an improvement.....are you making enough power to make it worth upgrading the gearset?
a stronger box can make it a pain if you drive it daily, unless you are sticking with a helical gearset.
Yeh its a Maatouks Racing built motor running 526hp at the wheels on 98, I was almost ready to get a flex fuel tune & turn it up to about 700 - 800. I think I need to upgrade the box as 3rd gear is the weak link so probably as you mentioned a 1st to 4th helical cut dog box will be needed. It will save down time & money in the long run. It is my daily apart from road bikes & I don't think I could put up with an auto or justify a sequential.$22K
Today's project was to develop and tack up a 4inch metal intake pipe to suit the new turbo, coming along nicely, once I've positioned the weld in bung for catch can bypass line she'll be ready to tig together
hmm that's almost exactly the same as mine on 98, 395akwkw. Hopefully I'll have more luck with the box. I guess it depends how much you need to run daily, for me a box that is easy to live with is a priority (ie, factory, or at least a helical/synchro box)
All reassembled and airbox partition modified to suit and refitted, kinda sneakily looks like it's factory, the satin black hides its dimensions I reckon, now the wait for 2 weeks till tuning day😔
  • 1 month later...
Just be gentle into 3rd gear. I’ve spoken with the guys at ppg and decided on a 1st to 4th gears, billet main shaft & billet selector forks helical cut dog engagement   Works out cheaper than syncro.
  • 1 month later...
OK the gearbox is at PPG in SA & I'm about to send the clutch centres to HiOctane Racing in Sydney to get the clutch plate centres replaced with larger 26 spline ones so they fit the new billet main shaft in the gearbox.
PPG RB GTR/GTS-T Helical Cut Dog Gearset
PPG’s billet selector forks
PPG Billet RB Sandwhich Plate
PPG Billet RB Mainshaft
Transfer Case Upgrade
Xtreme Clutch 26 spline centres
now what will break next?
  • 4 weeks later...
  • 2 months later...
Since I don't often tow with it any more, the towball and hitch is in the boot, and I got this custom cover from ebay for the receiver.
(poor girl is looking dirty these days....we are a long way to the closest tar....)
  • 3 weeks later...
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
