Hi Scott,
What would "happen" if I had you to the swapover and install this without a tune? Or is it mandatory that this requires a tune to get it up and running
Nothing would go wrong (the ecu will protect itself), but you wouldn't get the gains obviously, and it would be rather laggy, coming on around 4k revs without a tune.
How long has stao had this out? I just got my billet high flow 2 weeks ago off him but he never mentioned it was new? It looks to be the same unless he's changed something I can't see in the pic....
Just released, not sure but I think yours will be the standard billet highflow, slightly smaller and different profiled rear wheel. Slightly smaller wastegate. Still good for almost 280kw on 98, this one just trades perhaps 200 revs of response for another 30kw or so, but I am only guessing at this point till someone tunes it up and leans on it.
Mine actually left the garage tonight, and it seriously needs a good wash and detail. I'm thinking once it gets a decent layer of polish/wax, it won't look so filthy after the rain as the water should slide right off...
  • Like 1
So just went to pick up a silicone joiner from the shop, who also are certified garret and holset turbo specialist. And queried the guy about hi flowing my stock m35 turbo, he said a stage 2 would cost me 1650 plus gst which is pretty steep, so does anyone in nz know where to get this done at a better price?
Hopefully get the quote back for the shift kit install tomorrow :)
Give this guy a call https://www.facebook.com/pages/Steve-Murch-Motor-Sport-Engineering/255636937679?fref=nf been told he knows his stuff
  • Like 1
^^^what he said. Not necessarily the cheapest around but certainly none better.
Then go to Soichi at ST Hitec for an HKS ecu and a tune!
Indeed +1 for Soichi. Did my fcon and tune!
Forgot about him actually, he is dam good at this stuff. So I'll give him a bell, have already spoken to Soichi about tuning which he's happy to do, but still have to complete supporting mods first,
How's your car going Dale? That fcon harness you sold me is dying to go on haha.
Stage 2... Not very descriptive.
Hard to pass on Hypergear's prices, and results. No other turbo re-builder would be modifying your highflow with 38mm wastegate puck to control the boost creep, custom billet wheels etc, and all for $1250...
I agree Scott. But do like to support my local if I can. For 1250 Aus plus postage I'm already looking at 1650nz to get one here and have the car off the road for the added shipping time and if I need to use warranty, same process.
I'll talk to the guys again about what exactly goes into a "stage 2"
He also mentioned he had done Vq/vg turbos in the past and wanted me to ask the sau guys if the oil lines have restrictors in them not just in the banjo but actual line and if the line runs through the block or simply bolt to it to pick up the feed.
Anybody sure ?
So he is selling you a product and hasn't even researched, not even a little bit, about it's intended application?
Yes there are 3 restrictors, and the oil pressure is twice what an RB runs. I have no idea what core he is trying to build so I can offer no advice on what needs to be done to increase the oil flow. Too much and the seals will leak, not enough and the bearings won't last long.
Just remember, if it fails there is never a warranty on turbos from my experience.
Lol it was literally quoted on the spot, I would be taking the car down for him to look at next time and give him a proper go at it.
Did anyone know that m24n is just a code for the material garret use.... Learn something new everyday
I hope he runs BB chra's, otherwise the oil flow will be insufficient and it will most certainly ruin any bush core. Been there done that a few times. Learn from my mistakes.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
