EDIT COMPLETE, here's my consumption
And I didn't drive it like a grandma. Keep in mind I said standard....so it was 190rwkw with standard everything except for FMIC, pod filter, JJR coilpacks, and 11psi
  • Replies 48
Posted Images
well atm i have had them for year. car idles fine, cold start always been good, makes 282rwkw on 15psi
mind u thats on a rich (11.5afr) e85 tune! re tune in a week or two for 25psi.
What Ive heard is it all depends on who does it. If they do a good job then it should be fine but also if its dodgy can be a disaster. Ive even heard of some guys freind doing it for him in hes own garage and aparently no complaints lol.
But personally I like to spend the extra and know 100percent I know what is in there is quality so in my book nismos ftw,
I just picked up from the guys at PRO-RACE a set of seimens 650cc injectors $492 ret, a top feed rail $290 ret, and a set if injector plugs from Coventrys $50 ret. I think its the cheapest way and its all brand new so you should not have any problems.
I'm personally not a fan of hi-flowed injectors, probably from one bad experience. A friend of mine had hi-flowed injectors on his 200SX and no matter what I did on the PowerFC I couldn't get A/F on idle or light cruise.
I suspect bad spray pattern, yes it will flow what you want, but it's pretty much acting like a hose spraying petrol instead of misting it.
Please note, I said from "bad experience".
i got my injectors hi-flowed by PJ Quick bits.
600cc @ 43psi
850cc @ 60psi
all flowed within 1-2cc of each other.
no issues yet with run in tune, pulled around 180rwkw @ 8psi, full tune in 1.5wks so i will report back with any issues.
I also had a set done by cef1ie and found them to work fine. Later sold them to another member and never heard back on a complaint. Cef1ie also ran the same thing in his own car to great results.
In the end I got a set of injectors back with one hole rather than 4, so it seems consistent with what was mentioned in the thread above.
ive got 740cc hi flowed injectors, not long after installing them my car developed a bad misfire from idle to 2000rpm, turned out to be inferior quality pindle caps fitted when they were high flowed, quite annoying that a 2c part ended up costing quite a bit in labour to have fixed.
my mechanic isnt a big fan of the high flows, as mentioned he reckons that when they are high flowed the spray pattern is pretty much wrecked. Idle and cold start isnt the best either, once its warm though its fine, apart from that though they do the job.
car is 214rwkw@10psi
Edited by bsd-gtst
i spoke to cef1ie and he said he doesnt touch the pindle at all just the screen so incorrect fitted pindle caps is a load of s*** so in saying that the spray pattern is not changed because the pindle is not touched
Edited by luvpsi
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
