JECS is a generic manufacturer, like bosch
it would be a std item fitted to the car most likely, ie; OEM part
ok because i found some JECS 55cc injectors for rb25det so i was wondering are they anygood it does note remanufactured so does this man they are highflows however they are red tops
https://www.sau.com.au/forums/topic/349955-jecs/#findComment-5619991
ive also been looking at these injectors it says they are from factory injectors does this mean they have been high flowed or just remanufactured to flow 850cc
http://cgi.ebay.com/ebaymotors/6-JECS-855cc-Fuel-Injectors-Nissan-RB25DET-_W0QQcmdZViewItemQQhashZitem3cb36e9e18QQitemZ260708408856QQptZRaceQ5fCarQ5fParts
https://www.sau.com.au/forums/topic/349955-jecs/#findComment-5621200
From the advert
Remanufactured: A properly rebuilt automotive part. The item has been completely disassembled, cleaned, and examined for wear and breakage. Worn out, missing or non-functioning components have been replaced with new or rebuilt components. It is the functional equivalent of a new part and is virtually indistinguishable from a new part. See the seller’s listing for full details. See all condition definitions
https://www.sau.com.au/forums/topic/349955-jecs/#findComment-5621239
most likely they are rebuilt, high flowed injectors. your call but I would personally just buy new ones. injectors are not super expensive these days an are fairly important....
+1
and by the time you get them flow tested m, check spray patterns etc, you could have just purchased a new set anyway.
https://www.sau.com.au/forums/topic/349955-jecs/#findComment-5622488
I have tested a set of sard 700s once and they were all within a bees dick of each other. never bothered again with new denso type ones (sard/nismo etc). have tested plenty of standard injectors though and found a few % variance is the norm.
https://www.sau.com.au/forums/topic/349955-jecs/#findComment-5622944
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
