Hi Guys,
I am going to modify my R32 GTR to run E85, my 1000cc injectors just turned up today!
And I have been trying to search around for fuel supply options for E85
I have currently got the following mods:
Rebuilt RB26 with forged internals
2860-5's
Nismo AFM's
full 3in exhaust
660cc injectors
Walbro fuel pump
Turbosmart E-Boost Street
std intercooler
K&N Filter in airbox
It made 350rwkw on a dyno dynamics @ 21.5psi
and made 317rwkw on a mainline dyno @ 20psi
Most people have told me that i'd need twin pump and surge tank setup to really make benefit of e85. but i want to try and steer clear from a surge tank in the boot because i've heard that there is fuel smell issues.
so an under car surge tank would be an option but there is very limited room underneath a R32, so where have people mounted surge tanks under the car if they have.
Also have anyone used any twin intank pump setups?
This would be the most attractive for me because it would be more simpler.
I have done track days and may do 2-3 a year, so its not a purpose track car. i dont drive it regularly hence fuel ecconomy and availability isnt much of an issue for me.
Even if i were to take it to the track again i would take my 3 20L jerry cans and make sure the fuel level doesnt drop below 1/2 a tank. so fuel surge isnt going to be a problem on track.
So if anybody has any results with a twin pump setup in tank please share it with me, it seems to be popular with the BMW guys, and on other forums like the WRX & EVO ones.
Cheers,
https://www.sau.com.au/forums/topic/350161-twin-intank-pumps-for-a-gtr/
  • Replies 61
Posted Images
You wont get any fuel smells if you do it properly with teflon braided lines, but it is still illegal.
Twin intank walbro's would be the go but a single GTR Nismo/Tomei should just handle that power.
^^^ on e85? Doubtful.
Powertune do a bolt in kit for twin pumps in tank. Do a search it's been covered before or call them up
Yeah there is a similar kit around too @ half the price, one of my customers just came in with one.... forgot who did it though.. :domokun:
mmm I'm interested. if you can find out who sells them I might grab one for my new car. want to switch it to E85. currently running a nismo pump, already has 1000cc injecotrs, after a nice 380kw or so with the 2530s it has but don't think the nismo pump will do it.
Yeah, if you could find out who the kit was through it would be appreciated!!
I'm just wondering how difficult it would be to modify the cradle and put together a bracket for the twin pumps to sit in?
also at what limit have people found the std fuel lines to run out of flow? what power levels do you have to run twin lines?
Cheers,
  • 9 months later...
I made my own twin walbro bracket. It surges at around 1/4 tank in my Stagea but that is due to the underseat tank mounting more than the pickup design.
A surge tank would be the best for track, even a small one may do the job.
Nismo intank pump, 400rwkw - no issues that we could tell from this. ID1000's
looked into all of this twin this, surge that, undercar etc... wasn't needed in the end.
pretty much same setup as well, built 26, 2530's.
on E85??
It's funny how similar our setups are.... but I am using HEAPS more fuel than you. Different ways of tuning to achieve the same result?
I'm pretty happy with the twin pumps i have in tank.
i managed to get them mounted in the stock cradle. after a heap of fiddling with the wiring they're running good now.
it turned out to be a bad connection clip in the fuel tank lid. removed it and ran an earth wire straight to the pumps and its fine now.
still a little low on power.
353rwkw on 24psi but hopefully with either poncams or a bigger cat back exhaust i can stretch some more out of it.
the exhaust is a little restrictive after the front pipe, front pipe is twin 70mm going into at least a 90 or 100mm collector and necking down to 80mm exit. then the decat has a 76mm flange so there is a fair restriction there.
Sort that out! It's all over the place! Its amazing what a well thought out exhaust does for these things... I made more power on less boost on SMALLER turbo's with an exhaust that works!
i was thinking the same thing earlier,
a decent turbo back exhaust will do wonders.. 3" is small for those huffers.
Edited by jangles
i suppose when you start shoving 24psi of boost through -5's there is a fair amount of air flow!
those restrictions are probably causing the graph to table top.
the exhaust does sound quite full of air when at WOT.
at least now we know that 3in will flow 350rwkw but at slightly higher boost.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
