My RB20s is breaking tractions in every gear at 5800rpm.
Im making two hundred firty kilowatts at the wheels, running chopped springs and 10 degree neg cambers on the rear, my tires are below the indicators and hard as a cats head...any suggestions how can I stop this torqueless animal spinning the wheels, no one else I know with an RB20 has this problem, is mine one of these illusive factory 'freak' motors?
Thank god you got banned, youre a goose plan-b.
i actually got angry byt the end of his rb20 wheelspin @ 5800 thread.
this guy is a moron. he should not be armed with a set of car keys.
LMAOOOOOOO did he say this I didnt see it. There was another guy with a rb20 a while ago that had 215kw and was complaining about wheel spin through all 5 gears. Probably just clutch slipping for 5 gears lol.
Have a look through the wheelspin at 5700 thread. Try to find the first person to say a nasty comment.
It's him!
Aside from me asking if he was taking the piss, everyone was giving constructive answers. Then he just turns on everyone (inc Ash - lol)
I took an instant disliking to him from that point. He could be a nice kid but he needs to take a different approach to constructive criticism
you can get 300 cc out of 270cc injectors with an aftermarket fuel pressure reg so if you run 10 more fuel pressure regs it will make 500 hp easy
Oh ok. So if my maths is right:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
