Talked to the Link factory in regards to high revving RB26s and they say they reccommend an alternative triggering system. Doesn't apply to me as my RB30 won't be going over 6800 so I don't know what people are doing but there are two or three different approaches. I read about a year or so ago that Unigroup had such an alterrnative triggering system?
The Unigroup one is the one they developed with Ross. $2k (plus $1k fitting). It's happening in my car and another on here at 5500, so well before high revs.
I'm going to talk to CRD again today to see if I can find out more about what they do.
Edited by Scooby
mark - the way you fix your issue is take it to crd :)
a few of us here have heard this timing issue more than a few times with unigroup, however, jim @ crd has NEVER raised this sort of glitch with my setup (food for thought)
ive heard very good things about yavus though
Interesting read, I've never had this problem because my old R33 wasn't a power house, but I'm imagining that because of the massive ramp in RPM, the alternator could be producing sht loads of current and the rectifier isn't keeping the voltage flat.
Perhaps try soldering an inline capacitor to the +ve of the CAS or just run a big car audio capacitor to minimise voltage fluctuation.
Hope that helps.
Imagine people were just soldering on capacitors? $2 piece of silicon charging $500+
I don't think it's so much electrical interference as it is physical 'noise'. cas is rotating fast and if a bit worn etc gets problems. the other side of it is the type of ECU being used. some are definitely more prone than others. there is a cheap trigger disk solution, or the best fix is the crank damper pick-up but as stated above it's not cheap.
Is this what price im looking at to get my CAS fixed..? :S or is this a new one?
Edited by Aleckr33
The symptoms are described here in a thread from the Haltech forum:
http://forums.haltech.com/viewtopic.php?f=23&p=28152
and here
http://ljracing.co.nz/
Spoke to Haltech today, they said that their Platinum ecu has no problem handling the Nissan CAS signal but they're aware that some ecus do. Also read that somewhere that one got their hands on the patent for the Nissan CAS signal sensing and it was very impressive in terms of sophistication, so could probably work well with a 360 slot CAS trigger wheel.
Also Mark from Godzilla was as always very helpful, he hasn't invested in the trigger disc solution but has heard of it and was talking to Speedtech NZ who apparently have trigger discs made up. Then it's just a matter of telling the ecu to run 12+1 or 24+1 depending upon the wheel. Irrspective of who's solution it is, modifying the CAS can't be much mre complicated than that as there's not much in there.
Yeah Marko there's no doubt that CRD will know what to do, but I like to have some idea of what's being done to my car for future reference, no matter who does it, and at the moment they're not giving anything away. Respect their position but hey, it's my car.
Richard you refer to a cheap fix but do you know anyone who actually does this in Sydney?
Jack thanks for the tip re Red R, I'll get in touch.
Aleck no mate that's for a full crank trigger system that's good probably good for 10k ish rpm plus. Hence why I'm after what appears to be cheap and effective solution.
Edited by Scooby
could the trend be the ecu thats being used?
Most of the trigger issues are with particular ecu's not liking the nissan pattern.
Maybe post the ecu's (and engine combo) that are having the issues?
I can say its not inherent in nissan CAS's especially in these cars which are being mentioned.
A simple way to tell would be to just an oscilloscope on the CAS signal and see what it looks like at 7000rpm pre and post loom, if its clean on both then the issue must lie with the ECU.
Quick update, used another CAS and got to 6k rpm before the scatter appeared. As per Jack's suggestion got in touch with Red R Racing, Paul was very helpful and is sending down a CAS with a 24 (?) slot trigger wheel to try so looking forward to the results. Will post again when results are known.
Good stuff mate, it will be interesting to see if it eliminates the problem.
Keep us updated......
steam ftw
i have heard of CA's having the same problem, there is a data log file in the Haltech formus that shows the CAS signal from a CA that was inflicted with this issue.
EDIT!! Here is it.
Wow, I really didn't think this was a topic that was soo miss understood.
Timing jitter is something that has plagued RB engines since the dawn of time. The worst is the 30 single cam.
Now fact of the matter is, you are measuring the crank off the camshaft. Now between the crank and the cam sensor we have......
A bearing that the sensor shaft runs on.
The shaft it self that goes in the camshaft.
A rubber belt.
Now, there is an easy way to diagnose if you have timing jitter. Lock your ignition timing. Grab a timing light and slowly rev your engine..... and watch the timing.
You will see as your belt gets harmonic vibrations so will your timing. Every RB does it. Just some do it worse than others.
Now, there are some fixes. using a dual pulse disk can help. It basically dumbs down the CAS so its not as accurate but helps jitter.
The best option is measure the crank off the crank. I have just been involved in making a bolt on billet kit for RB series engines. We started with a 72+1 then tried 72+1 with a missing tooth.
The problem we had was the sensor we where using wasn't fast enough to read it at 9000+ rpm.
We ended up with a 24+1 setup so RPM is never an issue and still more than enough teeth for accuracy.
I have personally seen engines sooooo bad that the timing marks disappear off the balancer.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
