  • 1 month later...
Final few bit's and pieces have come back from the powdercoater. Also received another pile of parts from the guys at garage7 including some heat control items (gold film, heat wrap etc), carter lift pump, sway bar end links etc.
Looking awesome Nick, it's changed so much since the last time I saw it in person!
By the way, where did you get your stuff powdercoated?? Looking to get my rocker covers done but haven't found a place in Perth who will do small jobs like that...
  • 1 month later...
  • 1 month later...
A few more updates - this project has taken a back seat lately but I manage to squeeze an hour or two in occasionally.
Getting to like rivnuts - used them to mount the battery
Tried to make a start on the new fuel feed line but straightening it is as far as I've gotten
Battery isolation mounted on the shifter surround - looks close to the shifter but it's actually in third here.
Another bracket - this one for the lift pump which is going under the boot floor.
Reading Harry's thread (http://www.skylinesa...136-dr30-build/) reminded me I need to sort out the rear camber so I pulled out the rear subframe only to find this :(
Steve May helped out with a new subframe which is off getting the standard bushes pressed out. Harry's mate Brae machined up these solid bushes for the new subframe (cheers mate!) - almost seems a shame to stick them under the car.
Had some set backs fitting up all the adjustable front suspension gear so while I'm waiting for some replacement bits to be machined I got into one of the more enjoyable jobs - putting together braided lines.
  • 3 weeks later...
Thanks Brae - yeh the subframe is a mess! After you mentioned it I gave Stewart Wilkins a call and now a camber/toe kit is on it's way - pretty much the same set-up the Gibson R31's used so hopefully it gives plenty of adjustment.
Also had some more machining done - new 4340 king pins for the adjustable LCA's after the ones supplied with the kit galled (forgot to use anti-seize, but seriously - who zinc coats critical fasteners!?).
  • 3 weeks later...
Vacuum lines for the two WG's has been a bit of work but it's coming together reasonably well and provided a nice break from lying under the car!
Almost done here, just missing one line and then I'll cover everything in firesleeve.
Made a start on the intake side - completed the rail to FPR fuel line, tapped the old PCV so it can act as a vac source for the FPR (bottom middle) and also tapped the coolant bleed point for the header tank (bottom left).
The new subframe to replace the butchered one had some surface rust so I've been cleaning that up before it and the trailing arms go to brad stacy. Driveshafts and diff will also get some attention.
The adjustable trailing arm parts
Most of the front suspension bit's and pieces are in now as well.
very interested in seeing how the trailing arm bits go.
i got under the gibson 31 at the nats and saw they'd mounted theres on top of the subframe. i think for helping the roll centre?
I'll post more details once they're welded in but bascially the RHS welds to the end of the inner mount on the trailing arm after chopping the std end off. Should give 15mm of adjustment and I'll weld it in 10mm higher to begin with. It's pretty similar to what the Gibson cars have done but easier to adjust - I'm not sure if the Gibson cars re-mounted the outer as well?
Powercruise?
Not at this stage. Still needs an engine and wiring but otherwise pretty close. Also just found out it needs new driveshafts which aren't particularly easy to find...
sweet, yea those stewart wilkins adjusters are the go, look the goods
btw with the shafts ive heard u can use bits from r32s to rebuild them ? i cannot confirm this but its on my to do list
Edited by ydr030
Should upgrade to an R33 rearend. They're easy to find.
If I could find someone that I trust to do the work I'd consider it but unfortunately my preferred fabricator isn't interested. Given I already have a 2way mech diff, billet axles and coilovers to suit the current rear end machining billet driveshafts would be the next step. I'm reasonably sure breaking the diff mount and dragging the diff/subframe along the ground is the cause in this case...fingers crossed.
Interesting!! I might grab some r32 shafts and see what's interchangeable - I'm assuming GTR? It's just the CV's that are the issue in this case - the shafts themselves are fine.
Nick, long shot but possibly call Dick's cv's. Really old guy from mandurah that drives around, visits Bunbury every 2nd tues, he might head your way every now and then and may be able to help
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
