Engine is finished now :D
Only a week to get it Tuned and run in.
Nick and Ben over at GT Garage are doing an amazing job and working their fingers to the bone in order to get it done before the weekend so I can go in the Tas Drift Festival.
Some engine pron for you
Super happy fun times await. Hopefully I can pull a decent slide in it; it'd be a little embarrassing if I couldn't pinch.gif
Holy jesus that's one sexy looking engine bay... I'll be dropping in to the drift festival for a few hours today, keep your bonnet open and I'll come and have a looksie. Good luck with the competition, hope to see it in action!
Jay
I'm pretty sure this cars day went something like this:
1. Off
2. Warm up lap
3. Limiter
4. Limiter
5. Limiter
6. Go home time
Sounded awesome and the engine definitely looks the part (thanks for leaving the bonnet wide open, had a good perve).
Interested to see exactly how you mounted your fire extinguisher, it's exactly where I was planning on putting mine :) Oh, and how'd those sway bars feel? Any adjustments on the day?
It was just an issue with fuel surging on spin out (as they didn't get time to fit the surge tank), was just playing it safe towing it off for a cool down and a check over.
Engine was run in on the dyno before the day.
Edited by SKiT_R31
Yeah I'm pretty sure it's the squishy fat thing in the middle that's letting the car down at the moment. But having never driven a RWD car with more than 60kw I think I'm going OK. Managed to link up the S's by the end of the day, got my hand out the window once too haha. Going to give her a go at the super sprints next week, hopefully I can get this car going with in a 10th of it's potential.
Here are some pics of my weekend :)
Loading up at GT
All loaded up :)
Quite intimidating :S
Pretty engine bay
Last minute touch ups with Dr. House...
First time giving it a boot full
Screamer pipe on full noise
Brown Trousers time
At this point I remembered my training... Kick the clutch 2m from the Apex....
Yeahhhhh!
Awwwwww
Just managed to hold on.
This hasn't gone to plan.
Yep...
Not gone well
No one saw that right...
The white menace lining up for Qualifying.
Trying to regain some dignity after the Driftkahna by frying em...
Still Sexy
Such a great weekend, one I'll remember all my life. Went from overwhelming excitement, to nausea inducing nerves, to sky high excitement and overall satisfaction.
Can't thank Nick and Ben at GT Garage enough for the enormous amount of work they've done on the car getting it from a clapped out ricer to the monster it is now, all in only 2 months.
Thanks for posting that up Dan, must have been at the end of the day when I was getting the hang of it.
Sway bars were really nice, the whole suspension setup was really really good, couldn't fault it at all, zero understeer, the car just did exactly what I told it to do, which most of the time was the wrong thing haha, but I'll learn.
We didn't make any adjustments to anything and I reckon it'll stay that way for a long time until I'm actually pushing any form of limit of the car. At the moment the car is only limited by me. I just need some more time behind the wheel :)
Edited by zoidbergmerc
  • 4 weeks later...
This is the interior if anyone was interested.
This has to be the only build in the history of skylines where there are less gauges in the after photo :P
How much weight did you drop when you emptied out the carpets/seats etc?
yeah haha, I need those gauges back though, the ones in the car were all broken and the new ones haven't arrived yet.
The original seats were quite heavy and the replacement seat you can lift with your pinky quite comfortably so I think a fair bit was saved there. The air bags were also quite heavy as well as the seat belts; but the rest of the carpet didn't weigh that much, no more than a couple of beach towels really.
The next big weight saving needs to come from the driver though, cutting back to zero beers and no junk during the week really made a huge difference, I still eat\drink what ever I want over the weekend though so it's not all bad. So far I've gone down 2 holes in my belt and I can fit into my old overalls that didn't fit two weeks ago. Haven't actually weighed my self yet though.
yeah but where does one obtain this dry ice you speak so fondly of?
not sure about that
http://www.google.com.au/search?client=safari&rls=en&q=dry+ice+in+tasmania&ie=UTF-8&oe=UTF-8&redir_esc=&ei=XiGtTbSiMOTdiAKss4zDDA
a few places by the look of it
i've never done it but i've seen a few diy's for it, you can use normal ice but it makes everything wet
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
