  • 3 weeks later...
Drifting tomorrow :D so excited.
shit's ready to rock.
Thinking I might need these wheels too.
http://www.importmonster.com.au/shop/product_info.php?cPath=40_45&products_id=1240
Thinking it's a pretty good price considering the tyres are included.
yeah that was brutal.
Got a video of it too.
Found a spare though thanks to Mr. Truscott :)
Car was playing up a bit so I spent a lot of time in the pits. Had some problems with boost controll, then after I fixed that the dash was playing up then after that the Diff was peg legging unless I gave it the full beans and a MASSIVE clutch kick. so yeah, pretty average day.
It was the best though when some kids came up and tried to take a picture of them selves with my car in the shot and my mum was like "oh hey boys, why don't you hop in and take a photo!" so they jumped in the driver seat and took some pics; totally made their day!
Edited by zoidbergmerc
It's great to see some young ones appreciate your hard work! Even if they don't understand what it is!!
I had someone ask for a ride at powercruise, first an only person to ask... But it was just after I'd pulled in for a split hose... Felt like a c*nt haha!!
Rekon diff is shagged or needs some new good oil?
what sort of boost control are you running? haltec or standalone?
do you have an aftermarket diff or just standard nissan viscus?
he's running a nismo 2 way as far as i'm aware. oil probably came off the good ship, titanic and needs to be released back into the wild
Edited by Mr. Untouchable
Yeah Nismo 2-way.
Haltech does all the boost controlling. I think I've isolated the problem, just need to have a fiddle to see if it fixes it. Just some settings in the ECU need some tweaking I reckon
What oil should I put in my Diff?
im not sure what you should run but you can get nismo lsd oil off just jap.
i have heard people having a lot of trouble with boost control using the haltec and haltec solenoid. but others have non. it can also be caused by the plumbing of the waste gate. i had a heap of problems with mine to start with as i plumbed it the same as on a few different cars i knew and it gave odd problems. had to change it to a somewhat complicated setup and its been sweet ever since.
Perfect Nissan Harmony.
Getting some new wheels, Getting the Lenso D2Rs (because everyone in the world has D1Rs) and I'm going to get them in black and paint the lip blue, to go with my blue NA GT badges pirate.gif
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
