I rolled mine with a 70mm pipe then gentley smahsed the f**k out of them with my 4pound snap destroyer cold blow hammer.
beeeeeeeyaaarrtiiifoool
FINE PRINT - YES it took me around 3 hours to then reapir each of them and shape them pissing around with my slapper hammer and various dolley's and contour guages, and then almost a full respray hahaha
well mine are a lot worse than Jacks, I'm a little disapointed, I couldn't see the damage that was being done until I stood up and the light hit it, looks like a retard has assaulted it with a bb gun -__- oh well, they're only guards on a drift car :P
you can't tell in the pics though! hehe. Pulled the fronts out about 20mm. I might have to spend the next 3 hours reapiring each of them and shape them pissing around with my slapper hammer and various dolley's and contour guages, and then almost a full respray
Edited by zoidbergmerc
looking at that lip though...they still dont fit? :blink:
i mean, youve fuarked the guards already, so might as well make them so they definitely wont shred your valuable slicks?
It's just the angle of the photo, it should be OK. Going to nubco now to get a bigger pole to pull it a little more just to be super sure. Looking at some old gopro footage, looks like the front wheels travel about 70mm so I'm trying to accommodate for that.
I'm going to raise the nose up another 10mm too, looking at the car side on, looks like it's under brakes already :P
Interesting tid bit.
I had my car on the turnplates and beaurepairs the other day and it got 41 degrees of steering angle (not sure what stock is, quick google suggests it's 36 degrees). Only mod is these http://www.gktech.co...uctID=NISS-TROD
They're good gear, I'd reccomend them to anyone with a skyline even if you're not drifting, just makes moving around so much easier, I can do u turns in the street and drive straight into my garage because of them :)
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
