hi guys, having a bit of an issue atm with my R34 GTT RB25 NEO. its been rebuilt and currently getting tuned,
the tuner found out the VCT wasn't connected so it is now connected but after 5000rpm it sounds like a valve is hitting the piston.
he heard this and turned the car off right away and D/C the VCT solonoid.
He took apart the timing belt cover and timing perfect and the TB has not jumped any tooths.
All clearances were checked and triple checked before bolting the block to the head.
It only happens when the is VCT activated, anything below 5000RPM, there is no noise and drives perfectly, idles perfect and no stuttering or hesitation.
Can anyone help me with this problem and to sort it out?
My car has been off the road for quite some time and this was suppose to be the final stage but now looks like it could be delayed longer by this unknown noise thats really got me worried :(
If anything, he will end up tuning the car without VCT activated.
Appreciate any feedback or input regarding this situation.
Edited by mill-180
Its probably knocking, if it were a valve hitting a jam pot there would be next to nothing left.
So wait, tuner tuned car with No NVCS then hooked it up and ran it up on the dyno? and it made noises....yup sounds like it was pinging its head off to me.
Also I'd find a new tuner if he didnt re-tune after hooking the vct up.
Even a few taps of piston to valve will bend the valves. If it hasnt been damaged yet then it might not be contacting.
Try turning the vtc on at a lower rpm and see if the noise is still there.
It might be pinging
and for ppl who said it drives crap with VCT turn off, i ran it in for 1000KM with the VCT turned off (i didnt even know it wasnt connected) and the car drove perfectly, no issues or felt "sluggish" at all.
Would a knocking noise be that audible outside the car?
Surely my tuner would know what knocking/pinging sounds like.
It might have driven perfectly without it. But with it it should be even better.
He should know what pinging sounds like. Its hard for us to diagnose sounds. We are just giving possible causes
well you'll be in for a nice surprise when VCT is turned on and you see the difference.
if you don't, then same as the other thread about it recently - the tuner is doing it wrong.
+1 for it being tune related.
At 5000rpm a valve hitting the piston is not going to end well. Think about human reaction time, it would have hit the piston at least 10 times at those engine speeds before he backed off. If the car drives fine now and es checked everything I don't think this is your problem
If the VCT is being turned off at 5000rpm then your piston to valve clearance gets bigger as the cam is retarding. Try giving it a free rev with it on as - in battery voltage across the two solenoid pins and see if it still makes the noise not under load. Is there any chance that it is PWM the solenoid after 5000rpm - they can be quiet noisy.
hi guys,
thanks for all the replies.
i was reading through this thread,
http://www.skylinesaustralia.com/forums/topic/353835-rb25-hi-flow-turbo-and-vct-help/
and it indicated that the VCT solenoid can be noisy and make clicking noises? it never did this before, is there any reason why it should be noisy now?
I am going to visit the tuner tomorrow and try and hear the sound myself first hand.
He is an experienced tuner so i trust his judgments, hopefully he is right.
I'd hate to find out that it was infact a noisy solenoid and he charged me unnecessary labour to check if the TB was correct.
LOL
Are you serious?
He is doing a process of elimination - fact is, that costs money and time.
If you want a proper job, dont be a tightass.
Better to rule something out initially than not at all especially with that type of noise.
You'd cry like a baby if it had smashed all the valves and he said it was just a VCT solenoid now wouldn't you?
Yeah I see what you mean nismoid, but the TB was triple checked before installing cover back on and I was 100% sure it wouldn't of been off. I guess he just wanted to be sure.
Now regarding the noisy solenoid, does anyone have a YouTube link to what it would sound like? Is it common that these would be louder then usual when it was perfectly quiet before?
Zebra; he was tuning for cruise then moved onto WOT and he found out the VCT was d/c so he got it connected, then started to tune again with the VCT that's when the noise occured.
Te solenoid works from 1500-4500rpm, then after it would turn off, if this the case, why wud it get louder after 5000? if it was infect the valve hitting the piston, then the damage wudve already been done and the motor won't even run anymore.
Hu uh a guessing game [claps hands]
a valve guide sliding up and down in the head
sorry for you though, its going to cost $$$ whatever it is..........and it will frustrate the hell out of you until you find it.
BTW I really don't know, without sound and being there its a guessing game.
VCT makes a huge difference, its like comparing an rb20 to an rb25
I had a similar sound from a motor I built. It was actually the timing belt vibrating and touching the lower timing cover on the side... might be worth a look.
Edited by BoostdR
I used to have mine triggered by a msd digital window sw and tried numerous on/off switchin pts and the difference was verrrrry minimal with the seat of the pants meter....waste of time in my book ......this was on the stock ecu tho, it only decresed spool time by a couple 100rpm
UPDATE:
ok its definitely not a clicking noise from a vct solenoid, sounds like a grinding noise.
the tuner set the vct to kick in earlier @ 2000rpm and thats when the sound occured.
Any ideas people?
If its only when the soleniod is activated then is got to be somthing with the vct mechanism???
When you say rebuilt did you get new pistons? A few people have had problems with the pistons supplied for neo engines and ended up with very high compression ratios suggesting that the pistons were not really suitable.
put it on a dyno, the difference is massive.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
