FOR SALE:
-S13/180sx door cards mint $80
-S13/180sx centre console mint $50
-S13 JDM mudflaps $40
-R33 dump pipe with ngk o2 sensor $40
-R33 near new intake piping GTS-T $30
-Apexi turbo timer 3 months old $50
-Avs rims + tyres x4 (made in japan) 16x9 $250
-3A high flow racing pod $15
-S13/180sx solid apexi intake adaptor and apexi pod $70
-S13/180sx passenger window switch $20
-Toyota supra RZ red spoiler $40
-Brand new 600RMS soundstream sub 12inch $200
-S14 cusco front strut brace $110
-S13 clear side guard indicators $20
-R32 clear side guard indicators $20
$16,500
Willing to accept stupid offers (Dont be silly though) wont be offended, no work = cant pay repayments.
Mods: 1000km ago car underwent major service replaced all oils and fluids, engine, diffs, brakes, trans, coolant with motul fluids, all done at Japanese Motorsport. Car is ready to go for new owner. 240rwkw running on almost stock boost. Tuner advised easy 300rwkw with bigger injectors.
Engine:
- Forged Engine
- R34 GTR N1 Turbos
- N1 Oil Pump
- Nismo Fuel Pump
- Nismo thermostat
- Pod Filters
- Tomei adjustable cam gears
- HKS 3" front/dumps into custom 4" exhaust
Exterior:
- Spoiler removed and holes welded
- Black 17 Enkei RP01 Wheels and new 235 tires
Interior:
- R34 GTR Vspec Seats, mint.
- Sparco suede steering wheel
- Pioneer headunit
- Soundstream 6" front speakers and 6x9" rear
Have brand new Greddy oil catch can and Apexi Power FC and EL hand controller ready to install worth $1500 alone.
Can provide more detailed pictures if required, no test pilots, welcome for me to take you for a test drive if serious.
Bump $16,000 o.n.o
All parts to suit R32 GTR/GTS4
Whiteline front and rear blade adjustable swaybars (Front 22mm, Rear 24mm). Includes urethane D bushes and rose joint link kits
All in good condition, bit dirty and what not but hardly had any use over the time ive had them
$500 for the lot, or swap for stock front / rear swaybars with link bushes etc + cash my way
Tein Colovers
No idea what spec, no leaks or knocks, one split boot (as pictured). Upgraded so these have come out
$300
GTR OEM Plastic side skirts + fibreglass pods
As pictured, bit dirty, but overall good nick. Pods fit between the door and the rear wheel arch
Paint code KG1 (Silver)
$200
2002 Kawasaki ZX6r, Great condition, well maintained, 41,000kms. New brake pads fitted recently, new Yuasa battery (old cheapy failed), new fork seals done around 6months ago. Lots of tyre left (<12mnths old)
$5,300 neg.
bump
Full set of work Kai 17x9+17 all round I think, they sit flush on my s15
Bronze colour with a bit of rash, two have ok tires other two are retread's. ..... $950. Located in Croydon pk 5008..... Text only, anytime...
0432 387 884
<br/><br/>Created with the Gumtree iPhone App.
Clearing out some parts that I have in the garage..
Most are negotiable.
Enkei 16" wheels (good condition) and tyres with plenty of tread.
5x114.3
Rear: 16x8, Front: 16x7
Made in Japan
$750 ono
attachicon.gifWheels attachicon.gifWheels2
R32 GTR driver and passenger side b-c pillar trim
$75
attachicon.gifPic
Genuine Nismo R32 GTR N1 rubber boot lip spoiler painted OEM white.
Has a few small waves due to rust. Still looks good can be restored.
$100
attachicon.gifNismo N1
HICAS hydraulic lock kit assembly whiteline
With hydraulic bypass fitting
Suits: R32, R33, 180sx, S13/14
New $200
ACL Race MLS Head Gasket CA18DET
New $150
Rear Subframe align & lock kit bushing (pineapples)
Suits: R32, R33, R34, 180SX, S13/14/15
Z32 300zx, A31 CEFIRO, N14 GTIR
New $130
Cefiro Rack Boots
New $20
Pioneer Carrozzeria TS-A9 6x9" Woofer + Speakers
$Make an offer
Rear R32 whiteline strut brace like new has just been test fitted
$150
S13 CA18DE top feed injectors (4)
$80
Razo Pedals
Manual with two spares
$Make an offer
RB25DET exhaust manifold. Due to a GTSR manifold i no longer need. $100
RB25DET standard injectors with out rail. Upgraded to larger items. $100
RB25DET inlet manifold. Doesn't come with throttle body or tps. Going ffp so i no longer need. $80
RB25DET S2 afm. Upgraded. $100
RB25 freshly mechined flywheel. Upgraded to a molly item. $100
4x15mm bolt on 4 stud spacers. Bran new only ever used to fit wheels, sprayed black. $150
Bump
4 x 17" V35 rims - rears are 17x8 +33, fronts are 17x7.5 +30 - 5 x 114.3 PCD & 66mm centre hub. These are the OEM rims off a V35 350GT non-premium coupe, but will fit many other models.
plus
2 x Toyo Proxes R1R 235/40ZR17 road-legal semi-slick tyres, fitted to front rims but not to car - never been used
plus
2 x Toyo Proxes R1R 245/40ZR17 road-legal semi-slick tyres, fitted to rear rims but not to car - never been used
The rims are in pretty good condition. They had a little bit of rash on the outer lips when I bought them, but I sanded it back & touched them up with a brush - they were track rims so I wasn't too fussed.
The tyres were bought brand new earlier this year, then fitted to the rims & balanced, ready for hillclimbs & track days this year. I haven't had a chance to use them yet, so the tyres haven't even been on the car. On an impulse I've bought an Akebono big brake kit, and the 17" rims won't fit over the front calipers - my loss can be your gain.
If you plan to hillclimb or track your car, these tyres will give you a huge advantage over street tyres.
I'm after $1000 for the lot, ready to bolt onto your car & go to the track. If there's no interest in these as a package I will consider separating tyres & rims, and also selling the tyres in pairs. I bought slightly different sizes because the V35 has a staggered fitment, and wanted to maintain that. The sizes I have are a lot closer front-rear than the stock sizes, and I would be happy to run them on any non-AWD skyline.
Interested - reply here or call me on 0418 841 730. Pics available if required. Pickup from Golden Grove. Perfect for the SAU SA track day:)
still got some parts left
RB20 Turbo great condition no shaft play. come with elbow pipe and dump pipe. $100
Manual Boost controller $20
R33 wastegate actuator $20
R32 RB20 front pipe $30
RB20 starter motor suit refurb $5
RB20DE injectors $20
Rb20 fuel rail $20
Bellmouth dump pipe $30
Stock R32 rear swaybar $30
RB20 stock intercooler with piping. suit turbo conversion $50
stock R32 S13 180sx rear camber arms $30 for the pair
Stock s13 180sx r32 (non hicas) toe arm $10
stock Rb20DE resonator airbox. good for gtting off defect $20
R32 4 door rear trims both sides $20 sell as pair only
2x JVC 6x9 290W speakers $30 for the pair
sony Xplod heat unit CD player with loom $20
6x9 ported boxes with wiring. $20 each or both for $30
R32 GTS-T Type M Leather steering wheel, very good condition $80
Contact via TXT or Call on 0416 580 two two three
R33 Series 2 skyline GTS-T Immaculate condition for its age, possibly on of the cleanest in SA
95,000kms. Only done 40,00kms in the last 8 years
Only australian owner
Only selling as i dont drive it that much anymore and would like to buy a boat.
Contact Brad 0409699742
$14,000 open to offers
All details are on carsales link below.
http://www.carsales.com.au/private/details/nissan-skyline-1996-14598191?base=1216&vertical=Car&cr=45&page=4&eapi=2&__N=1246 1252 1247 1282 4294963846 4294963593 901 1216&num=15&silo=Stock&sort=default
SOLD
Bump also selling a s13 strut brace that's been drilled out to fit a r31. $130
Turbosmart bov adaptor. See image below but its capped so you don't have to plate the bov for flutterz. $50
http://www.sonicperformance.com.au/productimages/TS-0205-2057.jpg
Couple more things added.
R34 RB25 Neo Parts
Bosch 550cc Injectors - Direct drop and comes with everything needed.
$350
Nisstune ( If you have standard ECU, we could work something out)
$450
Brake Master Stopper
$100
Blitz ID III
Boost Controller
$350
Eyelids - Painted Factory Blue
$100
Cusco Upper Front Camber Arms
$200
Cusco Castor Rods
$180
All parts located in Adelaide, or willing to send at buyers cost.
Genuine Nardi 330mm Deepcorn perforated leather steering wheel. Brand new still in box and packaging, has card verifying that it's a genuine Nardi. Horn button is included.
Located Adelaide hills, will post at buyers expense. - $300
post-96537-0-23832600-1367133036_thumb.jpg post-96537-0-41666000-1367133041_thumb.jpg post-96537-0-36315400-1367133046_thumb.jpg
Edited by brentos_mentos
Nissan Skyline R33
Contact: O4O2 9O2 759
Factory Turbo Manual
Series 2
121,000 km
3" Trust Turbo Back Exhaust
Heavy Duty Clutch
R34 GT-T Wheels (R34 GTR Wheels have been removed)
New Tyres with above 90% remaining
Coilovers (Height and Damper Adjustable)
Pod Filter
New Front Castor Rod Bushes
New Upper Front Control Arm Bushes
New Water Pump
New Timing Belt
New Spark Plugs
Major Service Completed
All electrics working, AC is cold, Doesnt blow any smoke, Smooth Idle.
Makes a for a great daily with a bit of power. Currently running stock boost.
Not currently registered but can be done online for new owner.
Does NOT come on R34 GTR wheels, will come on R34 GT-T Wheels with new tyres, (extra $1500 for R34 GTR Wheels)
Price: $9,950
Edited by JiN_MaN
Tein Colovers
$300
Interested In these cant Pm you? Can you Pm me?
For sale polished R33 GTR wheels 17x9 +30 tyres are ordinary.
$1000
prob best to pm me
Im a fly in fly out worker, so if you dont get a reply Im prob at work. I have about 5 weeks of leave left at time of post.
post-88299-0-37803600-1367219272_thumb.jpg post-88299-0-66259500-1367219258_thumb.jpg
Car has been sold and want this stuff gone. Pics on gumtree: http://www.gumtree.com.au/m-my-ad.html?adId=1015847989
Mostly series 2 R33 unless stated otherwise:
R33 series 2 front bar with nismo lip (Kr4 silver in colour) $300
R33 series 2 bonnet (Kr4 Silver) $300
R33 series 2 rear bar SOLD
R33 series 2 spoiler (Kr4 Silver) $50
R33 crossover pipe $30
R33 HKS adjustable actuator, bought but never fitted. $50
R33 skyline power fc brand new in box with controller gtst rb25det SOLD
R33 Rocket Cover Kit $30
GFB boost controller silver $40
R33 rear tail light $20
R33 Standard cat back exhaust and rear muffler box $80
R33 Dash silver overlay $20
R33 Gtr 400r indicators $40
R33 Air intake $30
R33 Standard dump pipe $40
R33 Exhaust gaskit kit $25
R33 Rear pods silver $30
R33 Coilpacks series 2 one is dodgey $40
R33 Exhaust manifold Block to turbo $50
R33 Standard Cat $40
R32 Turbo with 25 actuator 1mm of play, think it came off a 32 at 80,000kms and hasnt been on since. $100
R33Standard Side mount intercooler $50
R33 return pipe $25
Everything is in good to great condition.
If i dont answer im at work send me a txt. Brad 0409699742
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
