reposting my Stock 17 inch Stagea wheels...
$350.
Tyres are basically brand new generic brand, wheels are also almost prefect aside from one tiny mark.
I can sms pictures to anyone interested.
Pick up only from Seaford area.
Cheers folks.
Edited by Beregron
R33 boot trim Make an offer
R33 straight pipes turbo back mild steel, cannon at the end. $200 Ono
r33 front adjustable strut brace $70
Sr20det manual ecu $90
Genuine type x spoiler 180sx $110 Ono
s13 stock front and dump pipe $50
R33 battery tray with fuse box etc $40
RB crossmember with 33 engine mounts $50
R33 manual tailshaft $80
Set of Vskfs 18x9 +33 & 18x9.5 +39. Had them in the garage for a few years and need the space
drift wheels as theyve got gutter rash and 1 has a minor kink in the inner lip.
Or u could refurbish them.
$600 obo wont go lower than 500
Willing to swap for parts, ie. EBC, JZX100 parts (coilovers). I'll try get pics uploaded tomorrow.
post-16827-0-49841200-1374109457_thumb.j
The wheel with the inner kink, I dunno how the previous owner did it but I bought these wheels like it from Japan and was misinformed on the actual condition of the wheels:
post-16827-0-75746200-1374109644_thumb.j
Work Euroline DH -pretty good, some minor rash on 2 rims, does NOT come with tyres.
5x114.3
18x8 +7
18x9 +7
Suit Toyota, Nissan and Ford
-$1000ono
post-16827-0-88872300-1374110119_thumb.j
S13/180sx Front reo bar UNCUT
-$60
post-16827-0-27517300-1374197982_thumb.j
very keen on vskfs pms sent
  • Like 1
For sale - Logitech G27 Steering Wheel / Racing Wheel in perfect condition. Includes wheel, pedals and shifter. $400 neg.
Located Adelaide (southern). Pick up only, local delivery can be negotiated.
Mounted on a home engineered stand. Pedals are adjustable for position on base.
Wheel angle, wheel height and shifter are adjustable to suit your seating position.
This stand has specifically been built to suit a lounge/couch seated position. Can be adjusted to suit any seating style.
Wheel/stand folds down flat for ease of storage, trolley wheels to assist in moving it around. The base is quite thick/heavy to ensure the set up wont move around with intense racing/force feedback from the G27. Rubber feet also ensure it grips a tile/slate floor surface.
Perfect for you PS3 or PC, works amazingly with GT5 and LFS.
not loud enough still bud?
Haha, I didn't even try putting it on, changed my mind again so the current one will be staying on there for now. :P My ocd kicked in. :( Is my old exhaust quiet enough for ya? :laugh:
Brother MFC 9210 printer for sale $100
It would make a good small office printer. In excellent condition. Pick up only Nth Suburbs
Brad 0427999093
Bump $50
Pair of Britax LED beacons for sale
(as most would have seen on either my Patrol or on my Ranger)
These are 2 spare units that i have that are now taking up space. If you're needing a yellow flashing light for your vehicle for going onto a construction site, these are a good bang for buck unit
Specs:
Clear Polycarbonate Lens with Twelve LEDs
12 Auxiliary LEDs in the Top of the Beacon Provide 360° Vertical and Horizontal Coverage
Waterproof, Shock Resistant, Potted Circuit Board
Permanent Mount configuration (if you want to mount them on a standard roof bar mounting plate, the holes are standard pattern the same as any Narva or Hella flashing light unit)
Black Powder Coated Die-Cast Base
Thirty Built-in Flash Patterns, Including Four Simulated Rotating Patterns
Alternate or Simultaneous Flash Patterns with up to Eight Connected LED Beacons
12/24V applications
Come with instruction book, laser cut brackets, and pre-wired with Narva waterproof plugs
$200 for the pair
Contact me via PM
R33 3" Catback to AMPerformance 4" Twin Tips.
Asking $400.
Bump, $350!
its perfect bud missus just wants to change the big ass tip haha
Haha awesome! Nothing wrong with the tip! :P It even has the 'Momocorse' logo on it! :laugh:
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
