reposting my Stock 17 inch Stagea wheels...
$350.
Tyres are basically brand new generic brand, wheels are also almost prefect aside from one tiny mark.
I can sms pictures to anyone interested.
Pick up only from Seaford area.
Cheers folks.
Edited by Beregron
R33 boot trim Make an offer
R33 straight pipes turbo back mild steel, cannon at the end. $200 Ono
r33 front adjustable strut brace $70
Sr20det manual ecu $90
Genuine type x spoiler 180sx $110 Ono
s13 stock front and dump pipe $50
R33 battery tray with fuse box etc $40
RB crossmember with 33 engine mounts $50
R33 manual tailshaft $80
Set of Vskfs 18x9 +33 & 18x9.5 +39. Had them in the garage for a few years and need the space
drift wheels as theyve got gutter rash and 1 has a minor kink in the inner lip.
Or u could refurbish them.
$600 obo wont go lower than 500
Willing to swap for parts, ie. EBC, JZX100 parts (coilovers). I'll try get pics uploaded tomorrow.
post-16827-0-49841200-1374109457_thumb.j
The wheel with the inner kink, I dunno how the previous owner did it but I bought these wheels like it from Japan and was misinformed on the actual condition of the wheels:
post-16827-0-75746200-1374109644_thumb.j
Work Euroline DH -pretty good, some minor rash on 2 rims, does NOT come with tyres.
5x114.3
18x8 +7
18x9 +7
Suit Toyota, Nissan and Ford
-$1000ono
post-16827-0-88872300-1374110119_thumb.j
S13/180sx Front reo bar UNCUT
-$60
post-16827-0-27517300-1374197982_thumb.j
very keen on vskfs pms sent
  • Like 1
For sale - Logitech G27 Steering Wheel / Racing Wheel in perfect condition. Includes wheel, pedals and shifter. $400 neg.
Located Adelaide (southern). Pick up only, local delivery can be negotiated.
Mounted on a home engineered stand. Pedals are adjustable for position on base.
Wheel angle, wheel height and shifter are adjustable to suit your seating position.
This stand has specifically been built to suit a lounge/couch seated position. Can be adjusted to suit any seating style.
Wheel/stand folds down flat for ease of storage, trolley wheels to assist in moving it around. The base is quite thick/heavy to ensure the set up wont move around with intense racing/force feedback from the G27. Rubber feet also ensure it grips a tile/slate floor surface.
Perfect for you PS3 or PC, works amazingly with GT5 and LFS.
not loud enough still bud?
Haha, I didn't even try putting it on, changed my mind again so the current one will be staying on there for now. :P My ocd kicked in. :( Is my old exhaust quiet enough for ya? :laugh:
Brother MFC 9210 printer for sale $100
It would make a good small office printer. In excellent condition. Pick up only Nth Suburbs
Brad 0427999093
Bump $50
Pair of Britax LED beacons for sale
(as most would have seen on either my Patrol or on my Ranger)
These are 2 spare units that i have that are now taking up space. If you're needing a yellow flashing light for your vehicle for going onto a construction site, these are a good bang for buck unit
Specs:
Clear Polycarbonate Lens with Twelve LEDs
12 Auxiliary LEDs in the Top of the Beacon Provide 360° Vertical and Horizontal Coverage
Waterproof, Shock Resistant, Potted Circuit Board
Permanent Mount configuration (if you want to mount them on a standard roof bar mounting plate, the holes are standard pattern the same as any Narva or Hella flashing light unit)
Black Powder Coated Die-Cast Base
Thirty Built-in Flash Patterns, Including Four Simulated Rotating Patterns
Alternate or Simultaneous Flash Patterns with up to Eight Connected LED Beacons
12/24V applications
Come with instruction book, laser cut brackets, and pre-wired with Narva waterproof plugs
$200 for the pair
Contact me via PM
R33 3" Catback to AMPerformance 4" Twin Tips.
Asking $400.
Bump, $350!
its perfect bud missus just wants to change the big ass tip haha
Haha awesome! Nothing wrong with the tip! :P It even has the 'Momocorse' logo on it! :laugh:
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
