ok,
I'm running a pair of Garrett GT 2860 - 7's in my GTR, and i'm getting full boost are 6k, which is way too high in the rev range.
I currently had a Gizzmo MSIbc installed, and I have tried a manual controller and its still lagging.
I fitted the factory boost control solenoid and it ran 8 psi @ 4k which is about right.
Anyone else had a problem with excess lag in a GTR? Or have any idea why its lagging so much?
Mate suggested that the wastegates are opening too early, if this is the case can I restrict them somehow?
Any suggestions welcome
-Michael-
https://www.sau.com.au/forums/topic/355457-car-way-too-laggy/
With proper boost control you should be at 16psi by 4k, not 8.
How did you setup the wastegate actuators?
A friend of mine is having the same problem with his GTR, twin GT-RS turbos, 272 cams, etc... Full boost by 5500rpm. I'll find out whats going on when he gets his car back from the tuner.
GT-RS are far bigger and laggier than -7s. Did you mean GT-SS?
Sounds spot on for those turbos and cams on a 2.6 or 2.8
he said thats whats under the hood, i havnt seen them myself. the car makes 460 awkw though. Would gt-ss make that power??
No way in hell mate, you have GT-RS x 2 there my friend.
GT-SS are hard out pushing 330KW let alone another 130KW on top of that, definitely GT-RS
The actuator rods have a thread on them so you can tighten / loosen them. This would be the first place to look.
Try tightening them up by screwing the end on so the total rod length is shorter. This means the actuator needs to see more boost before it starts opening the wastegate up further.
Well GT-RS turbos - what do you expect? 800hp of turbo isn't going to be responsive on a 2.6ltr
Sounds perfectly normal - and totally unrelated to the OP as he is talking about R34 N1 turbos.
Well you've answered your own question.
The EBC install is incorrect. If you've put the factory setup on there and it was instantly more responsive... Then it's rather obvious where the issue is...
Well if the EBC is the issue, it would have to be simply doing nothing. By that I mean having the same effect as no boost controller at all....would that really amount to that the increase in lag? Sure, it's been proven to be the issue by his simple troubleshooting - yet I can't see how a boost controller will be the difference in 2000rpm
+1. After you tighten the actuators, make sure they are both working in unison by applying boost to the signal line, and making sure they move together. Otherwise you could flog out a turbo.
For clarity, it appears you have two boost control problems.
1. Probably actuatory adjustment
2. Boost controller installed incorrectly/broken.
True this - very important the actuators are configured consistently across both turbos.
OK, i'll take a look at the actuators on the weekend, hope they can be adjusted without removing too much
I'm pretty sure the install is correct, there are 2 lines, one for actuators another from manifold. Boosts to target, just takes too long, old controller did the same thing, that's why I replaced it, thought the unit was faulty.
On the note of take it to a pro, can you recommend someone?
Thanks for the input :)
By target, do you mean higher than your actuator's spring rating? Try running a vac line directly from the boost source off the intercooler piping or wherever you're getting it from to the actuators. Completely remove the boost controller from the equation. You said with the standard boost solenoid in place, it made 8psi? If that's the rating of your actuators, I dare say that's probably the issue. While your turbos aren't HUGE, they're certainly flowing a decent amount of air and therefore exhaust even at that low boost, so I wouldn't be surprised if it was just simply overcoming the wastegate flap and pushing it open.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
