What stage pump are you going to be using? On our race car we run a 4 stage pump which scavenges two from the sump pan and then one from the back of the head. We are still using internal draining, though really the ideal would be to weld up all the oil returns and just let that one scavenge do the returning as that would avoid windage induced from oil draining right into the cranks vacuum trail. Has John considered doing something like that already?
Loving this build mate. Keep it up!
Interested in answer to this...
Here is a detailed Vid on how the merge of the wastegate pipe will be down. You need to listen to it with full volume and listen to what John has to say.
Always wondered about the advantages of something like that, following the direction of the turbine wheel/exhaust gas rotation.
The further this build goes the more impressed I am with the thought going into it.
Inducing swirl and/or taking advantage of it is very common in fluid dynamics and effective. Clever.
I am running a 4 stage pump, and yes the ideal way would be to weld the oil drains up , and we did not weld it however we have used bungs for all exept the ones on each ends of the head.
Ok,
The latest is the merge is getting cut up to form the shape that John had said on the Vid above i should be able to get some more pics on it tomorrow.
The next step is to install all the Motec system i have done some work in installing it, will get some pics up tomorrow. The other thing i am installing is the zeitronix E85 sensor to determine the concentration of Ethanol.
I should also get some pic of the bottom end as this has been completed.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
