Here are some photos of Bobby's RB26 head with porting and modifitcations.
Bob would you like to explain what's been done here?
Thanks
JEM
Not sure if anyone has noticed the exhaust port, the bump has not been cut out, I know everyone out there has cut this out but john has not cut it out?? let see who can tell me why??
I honestly have no idea, but ill take a stab at it causes turbulence which helps bind the pulse together, so ultimately it will hit the turbine wheel more effectively.
Well the correct answer is, there is a water gallery right behind it if you cut it out your wall thinkness is reduced to <1.5mm think, this was found when we got a rb26 head and John started to cut sections out of it, he has checked the whole head where he could gain more performance from it and at the same time keep away from any thining walls.
You can see it in the below pic
The motec setup see below pics
M800
E888
Ignition Expander
Shift light
M800 - Will run all the factory sensors plus run twin Nismo AFM no Map for tunning. Control diff, trans, and front diff cooling pumps, Dual lambda, custom wiring for 12 injectors all running sequential ,speed controlled Fuel Pump, fuel pressure sensor, fuel temp sensor. E85 analyser for ethanol content (zeitronix sensor), water methanol injection
E888- Will be used for 8 k type thermocouples installed in the manifold runner and exhaust, 4 pressure sensor exit of compressor housing to the plenum. 4 air temp sensors exit of compressor housing to plenum. Compressor wheel RPM,Diff temp,trans temp.
Ignition Expander - this will control the sequential IGN as the output on the M800 are used for the other set of injectors.
Shift light - This has three different colour on each light that can be configured for warnings and shift lights
Motec would have to be one of the best ECU system for a car as you can make it do what ever you want it to. Yes it is expensive however if you want to do it properly then this is the product.
I was very happy that Just Engine Management is a dealer for Motec and Adam at Jem advised what the car needed, i guess this is just the beginning as i am sure i need alot more Motec equipment to complete the car.
  • Like 1
The wastegate collector has been slow as John has been busy making the die.
See below Vid
He is making this die so he can beat the pipe into this shape for each of the two wastegates entering the dump to form a venturi. I know this is getting out of control however i guess, him making these things is all a challenge to him also.
  • Like 1
bobby, with motec it doest stop haha by the time i finished with my car it was well into the 30s!! wiring, slm, dash, 1 million sensors it gets up there fairly quickly!!
Yes i know i was just told today i have to use some special wire "tefzel" for all the sensors with raychem.
Also i dont see anyother ECU out there that can do what i need it to do.
Awesome build dude keep us posted !
I know of a good ECU "Apexi power fc" does the job for me lol
loving the thread mate. great stuff. I would love to come and talk with john about his ideas one day. he is a fantastic craftsman that's for sure.
I run a motec in my 32 too, not nearly as comprehensive as yours though! but it does run very nicely.
I'll echo some previous thoughts on using an EFR turbo. I have a lot to do with both borg warner and full race at the moment and would be happy to make an introduction? I'm sure they could supply the info john needs to make an informed decision about their product. pm me if interested.
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
