having met john and spent a few hours(!) talking to him I have utmost respect for the man. he has amazing skills and a brain that operates on another level to most. I have a pretty high IQ but john must be off the charts. Very nice guy too and not afraid to tell what he thinks and usually has very sound arguments to back his opinions too. he has some amazing ideas about a whole range of stuff.
I've no doubt this will be off the charts. I want to go back and ask him some more stuff. just need time for my brain to digest the last bits of knowledge he dropped on me!
thanks very much bobby. I really appreciate the intro mate. and your time too. :)
You lucky duck!
Hey Richard,
Glad that you liked the meet with John.
Yes it does get like that, does take time in digesting his knowledge.
Speak soon
Below pic, I have installed the Zeitronix Ethanol content sensor that gives you the concentration of ethanol in E85 Fuel. This is a must when running E85, last thing you wont to do is give it a hit and you lean out cause the ethanol content has changed, this is connected to a return line. Just Engine management is a Dealer for Zeitronix products.
http://www.zeitronix.com/
Theres a writeup in the Forced induction section if you dont check it often, by a guy who has used that sensor with a Link ecu, a local tuner has got the car running on anything between 98 and E85. Check it out, good read.
Yes very well put together thats if you want to run 98 and E85, what i am trying to do is only run E85 however as you know the concentration varies so we need to know the ethanol contant accurately . Tune can vary to fuel temp also when using E85 i have noticed he has not allowed for that.
What's the plan to alter the mixture of E85 if it is found to be varied from the original tune state? Add denatured Ethanol and/or BP98?
What do you do with ignition tables in regards to varying ethanol content/fuel mixtures? Add an extra dimension vs ethanol content? Sounds like an absolute mission to get running at an optimum level.
I'd think that the optimum/safe ignition advance would vary widely when you started mixing fuels together, as opposed to making ethanol content based corrections to the fueling table which would correlate directly to ethanol content..
Below is an update of the wastegaste Venturi.
Progress has been slow as John is having alot of problems panel beating the 304 stainless as it needs to be annealed every time he needs to beat it and the time frame is short before it cools.
Looking great!
was at outback steakhouse with him couple nights ago
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
