  • Replies 161
As Kyle from 6boost said, it was the only way to get a decent design. Worth it if the gains will be what I expect. Only way to get ahead of the pack is to go outside the norm..just gotta make the right selections ;)
Matt
Engine is in. Rear turbo inlet pipe fouls on the Strut tower.. I gather the manifold sits the turbo's in a slightly different position to std. More custom work required.
The Gearbox was also insanely hard to get in with the rear head drain...was hard enough with the Rb30 and sump adaptor which stops the motor tilting down as much. Its a pry bar job now.
Matt
Edited by BoostdR
If there are gains to be had... I'd be keen.
Saying that... by the time we'd buggered about with buying/fitting the manifolds, modding the intake pipe work, modding the oil and water lines, 'adjusting' the dump pipes/down pipes etc...
... aren't there a pair of top mount, external gate turbos to fitt- they may result in better performance??? for no other reason than there is not as much comprimise for fittment or wastegate size???
I don't know? I guess I'm asking the question- hmm.
What ever the answer, I like what BoostdR is doing- I can't wait to see the results!
Cheers
J.
PS. BoostdR- Do you get much low end comp surge? If so, I'd love to know if these manifolds help illiminate it..
I did have compressor surge before....only when boosting in a low rpm high gear. I feel the pipe kit will help this as I was still using the twin turbo pipe.
There are also alot of variation that could effect my rear turbo inlet pipe position.
Rb30 sits the head higher
Engine mounts position in the slots
Cast alloy hard pipe accuracy.
So if the manifolds are out a smidge and you used the standard rubber inlet pipes you wouldn't have and issue. Just very hard as the rear turbo outlet stops you doing that.
More findings today I'm sure.
Matt
Edited by BoostdR
Front pipes fitted up ok. I have modified the alloy hard pipe rear turbo inlet. There is about 5mm space from the front turbo wastegate and 10mm-15 to the strut tower. I also had to grind the upper suspension bolt for clearance as it protrudes into the engine bay by about 15mm near where the power steering resevoir is mounted. This has to be moved also.
looking forward to startup tomorrow.
Matt
Thanks for the kind words =)
I had to finish a 32GTR I had here today...took longer than expected so I have no updates for you.
I will get a some more pics. Makes more sense than my ramblings!
Matt
First start up, a few things stil to be finished
Sounds very sexual, quite different to before
Oil pressure was exactly what I was aiming for, 6bar(max). 1.1mm restrictor, std springs in reinmax pump
http://s1107.photobucket.com/albums/h388/boostdr/?action=view&current=fc70deb2.mp4
Seat of the pants results
Makes 1bar by about the same rpm, having said that it is noticeably more responsive from 1000-4000rpm. It makes 1bar just after 4000rpm however goes from 1bar to full boost in a few hundred rpm savagely. The motor also wants to rev, where as previously it would trail off around 8000rpm.
I had to drop the boost to 1.4bar as it's maxing out my 1000cc injectors. Will get some 2000cc for the dyno
The hard pipe kit has helped compressor surge, it still surges however is alot less and happily revs through.
Matt
Nice! Sound much different revving out?? So when are the new injectors and tune coming, and what boost are you going to run it to? Time for a new low mount 1/4 mile world record? ;)
I does sound quite different, louder and throatier. Injectors and tune won't be to far away. I just have to sort out some small issues, like why my Y intercooler pipe keeps blowing off and mounting my catch can... maybe also rotating the rear turbo outleft away from the front manifold.
No chance of a 1/4 mile run in Adelaide...we don't have a track :-/
Matt
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
