Hey,
Just a question in regards to VINs/Chassis Numbers. I bought an R34 25GT from Japan and it's just waiting for the next available ship headed to Australia. I organized compliance with a workshop and when they asked me for the Chassis Number in order to apply for a Vehicle Import Approval, I made the mistake of quoting the number in a public place where there's heaps of people around(I was on my break at work). So, if you overheard the number, what could you do with it? Would you be able to do anything that could prevent me from getting the car complied or registered or whatnot? I'm just hoping there were no criminals around me who rebirth vehicles and such, lol. :/
Maybe I'm just over-reacting. Anyway, comments would be much appreciated.
Thanks.
Once your vehicle is registered this information is available online to the public anyway.
VIN swaps or rebirths tend to happen when the swapper owns and has written off the original car, or stolen the number from a written off car at a wreckers (even then you'll have a tough time registering it).
Dood, bad mistake.
Do you know how much it will cost to re-export the car to Japan?
I never talk VIN numbers unless its with friends, and only if there is a cone of silence.
Not to worry...
I'm paranoid myself - but that doesn't mean that there's no-one following me. >_<
Mmm. But aside from all the jokes and such, nobody could really do anything with the chassis number, right? Sorry, I just don't know who is and isn't being serious. :/ lol
We have a thread where VIN numbers are posted so we can run them through Nissan's FAST so vehicle details can be confirmed.. Nothing can be done with them.. Well nothing that you could prevent.. The fact that you think some random car rebirther just happens to be near you and is ready to take the VIN/chassis numers down like it happens everyday is hilarious
Mmm, probably highly unlikely but you never know who is around... lol. Thanks for clearing it up anyway. :D
lol...I laugh at customers who are afraid to read me
credit card numbers over the phone...and then there's you...
Don't worry OP, everything is fine. Crisis averted.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
