considering the cars most of us drive (and i'm sure more than a few people interested / fascinated with Japan itself), perhaps we can have some sort of a charity event?
The easiest i suppose would be having a donation 'box' at the SAU Renewal BBQ/Dyno day - but perhaps people want a specific event all in itself?
And considering recent events with certain car clubs vs police in the hills, maybe we can get any club with Japanese made cars together for a bigger day, maybe even some media coverage of the day
thoughts?
  • Replies 40
already in the works man.... just gotta sort out some details! :)
sweet - i reckon hit up all the other SAU chapterz presidents and see if we can all have an event on at the same day around the country - and maybe see how far that can go, ns.com (a necessary evil) rexnet, soarer, supra have forums i think, surely there's some bits-a-missing forums. Nominate a 'holder' of donations, then present a massive novelty sized cheque to charity of choice
I know there is a show and shine japanese in the making with all money going towards the japanese more details will be up soon it a cross club org thing jzx100 NS toymods many others once final details are org im sure it will be put on every forums
Sitting duck,
guess you have not been to the knox tuesday night cruises
cars scraping gounds cars with no bonnets and cars running permits
and in the worst aera for defects and no one gets done as no one is stupid
if things like this can rock up and not get defected or even cars tubbed running slicks im sure you will be fine at a car park meet for charity hell the last one i drove a r32 4 door drift car there with rubber all up the guards plus mexican fitment as i was to lazy to change rims and i got there and back no issues
but comes down to your choice
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
