  • Replies 390
Posted Images
hopefully by the end of this year start of next, then we'll be talking fast. apparently the engine has something like 600nm's stock , with a blower OMG!!! that would be stupid, and im just the young stupid guy to do it!!!
good work NA_33 !
just a quick word on half cuts... (just finished a turbo conversion in my little Bro's L Series Subaru)
Check how long its being sitting around, coz the radiators tend corrode when empty - get it thoroughly flushed.Do the same with the water pump - there buggers to get out once the engines in.
just a couple of things i found out thrpugh experience - blocked water galleries in the block - pains in the a** to flush out !
best of luck anyway :)
hahahaha, yeah true!!
New Update:
The engine is now out of the halfcut and we discovered a broken timing chain guide so that has slowed things up abit but apart from that the engine internally looks awesome, never been to hot or run out of oil and all parts have minimal where its unreal. Tomorrow ill pulling the engine out of my car and trial fitting the V8 and making engine mounts so it all seems to be coming together, ill try get some pics together.
Cheers
John
Is that R33 with audio install as pictured yours?:) if so have you gat any pictures of it in a build process? :wavey:
Is the R33 with audio install as pictured yours?:) if so have you got any pictures of it in a build process? :wavey:
yeah mate thats my install which is now all chopped up, and no i dont have ne in the build process other then that one, that was the unfinished state. Ive got pics of the build process for the new install. Pm me if you want details on how i built the one in my avatar, the best way would be to meet up some time and explain it to you, its kinda of hard to describe.
Genesis: If i wasnt at uni i would say almost definately, but it will be very tight mate, we'll see.
Update:
Ive done some more research and found a site with approx 600 posts with the same problem though everyone of these people had the timing chain jump teeth on the cam sprokets causing complete engine failure. So i have been very lucky with the engine and very lucky we found the problem and this website. Nissan rectified the problem in 94 with different tensioners so i now have a 10 day wait for the parts to come from Japan. I also managed to talk southport nissan into letting me see the wiring diagram for the car they generally dont show neone from the public nething like this.
Cheers
John
someone wanna give me there number or give them a tip?? thats like a dream of mine. one day it will be worthy...
Email Ben Ellis, he is an absolute top bloke and is the publisher for HPI, you can find his email address on the contents page of every issue, but here it is, [email protected] good luck mate.
hahaha, im never gonna here the end of this auto, i want to put a manual in, my mechanic, good friend, person doing majority of the conversion for me for free (all the same person) is very very persuasive, and "hi powered autos are awesome for drag racing, ur leaving it auto John" is what im told and thats how its gonna be.
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
