$60 for the whole kit including Ballast's? or just the uni globes?
I've noticed though, anything really above 6500k your Visuality just goes downhill, especially in rain.
I'm sticking with the factory 4300ks...I had 6000k aftermarket ones in my mazda 3 and it sucked ass in the rain/mist/fog...
took like 10mins to change the parkers didnt even have to take the wheels off........... looks SO much better now :D
Wish I had your small ass hands....
Mine are now LED- hope I never have to change them again.
i still jacked the car up just so the wheel was slightly off the ground HAHA
pretty sure my disc's need a good machining they dont feel the best under heavy braking or highway driving
whats the stock brake thickness so i can see if its just worth sourcing some vented disc's.............
Maybe I missed you stating so in the past (or just forgot), but I just noticed the Nismo rear wing on your car!
Subtle, but adds just enough :)
so its a nismo wing :) i love the wing looks weird without it imo
The stock disks are 22mm new, 20mm minimum if I remember right.
32 gtr disks are 32mm new, 30mm minimum, well worth the upgrade.
just measured my disc's there 296mm X 24mm.......... minimal wear on them, doesnt look warped but the surface from outter to inner is a bit wobbly
whats the best value upgrade...................???
** just found this:
Stock- 296 x 24mm fronts
R32 GTR non vspec - 296x32
R33 GTR - 324mmx30mm
350Z Brembo pack - 324mmx30mm
Edited by WAGON_BOY
** just found this:
R32 GTR non vspec - 296x32 will be the cheapest, anthing with "Brembo" written on it for a Skyline seems to demand telephone number pricetags; even if they've been thrashed to death.
Another option you have is R32 GTST calipers,324x30mm 350Z brembo discs and an offset bracket from conceptz perfomance or Ebay.
The advantage with the three you've quoted is the bolt on nature of them; only some simple bushes for R32 non- Brembo.
sweet ill check out concept z perfomance :D
Try this.:thumbsup: Quoted me roughly $150 to ship to my address.
http://www.conceptzp...158.165.206.187
Edited by Daleo
  • 5 weeks later...
thinking about doing a dump pipe back exhaust soon....... basically i want to do it right the first time, whats required to be able to flow enough for 300kw@w ???
got one of Scotty's dumps already.....
striaght throught 3" system or a 3.5"???
with a 4" rear muffler or whats the go???
cheers :)
Any of the big name Jap exhaust will do the job.
Fujitsubo Legalis R
Kakimoto
Blitz Nur spec
Nismo
HKS Demodo
plus probably a few others...I think all of the above are 3" systems...not 100% sure
Edited by ironpaw
kakimoto is 80mm 3.25"
i got it. its the best ive seen to be honest(may be biased as this is what i have) and its not too loud at all.
mines flowing so much its causing the turbo to creep with my highflow.. so if you highflow it. please make sure you get a new wastegate flap and widen the wastegate hole to suit.
im talking from experience.
lol
Fujitsubo Legalis R
Kakimoto
Blitz Nur spec
Nismo
HKS Demodo
Nup, the new Nismo is not 3"... nor is the Demoda for that matter.
Both 2.5" if memory serves me correctly.
Fuji Legalis and the Original M35 Nismo are 76mm and have basically the same design (very different muffler though)
Kakimoto (R or N1) and Blitz are 80mm
Demoda is rubbish for performance.
Charlestone exhaust....keeping it Local....I have had no probs with Hp development!!!
Unless if cause you want to flip your car to show shiny shot off!
Edited by Jetwreck
gonna get it made locally probly will a 100 cell cat, hotdog and resonater and muffler.
probly go with a magnaflow system............. other options are lukey and xforce
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
