finally after getting the wrong coloured facia its all back together and I have a radio again!!!
I've put up a thread with the wiring colour codes in case anyone else needs to replace theirs, cant seem to link if for some reason though.....
Http://www.skylinesaustralia.com.forums/topic/437160-m35mradio-replacement-wiring-colour-codes/
Finally got my go-pro footage from the SAU track day back on the 29th of Oct 2013 @ SMSP south circuit.
here was my last run where I got a free run with no traffic and managed 3 awesome laps
2x 1:09's and a 1:10.
http://www.youtube.com/watch?v=dcvL4eyt1qY
best of the day was a 1:09.14 with consistent 1:09's all day long :)
starting to get p*ssed off with all the little niggly bits, so I'm going to try and sort them out before I loos my sh*t:
1) redo my headlights
2) need to get the bonnet struts as the fibreglass bonnet is to flimsy to support by the stock arm and so the AXIS bonnet add on is starting to fall off.
3) this radio change over has been a massive PITA, hate the aftermarket A/C buttons, and seems as though I've blown part of the BCM that controls interior lights, tail lights and parker lights so now I need to replace the BCM which seems more or a PITA than it should be.
4) need to tidy up my gauges as it looks like sh*t so going to have to pull my finger out and make a fibreglass one!!!
5) should probably replace my drive belts and fuel filter I'm guessing they are well over due!!!
6) need to get this window washer bottle cos its a PITA having a dirty window all the time that I cant clean whilst I'm out
once all this is done I might feel better cos atm I'm getting annoyed my cars turning to sh*t because of neglect!!!
ah well that's my rant for the week!!! :)
I still have no 6 in pieces. :domokun:
I'll get cracking.
You makin a washer bottle Dale?
I did a cardboard mock up about a billion years ago for Theo; will use the OEM filler neck, and the side also acts an air guide for his oil cooler.
I have all the sheet guillotined and bent, neck made, then we had another kid. :rolleyes: I need to machine some bosses for the pumps to push through then get off my arse & weld it.
I'm so busy at work now, I barely get time to do my paperwork in the extra hour I work on top of my 12hr shift. Weekends used to be fab time; not anymore.
It might hold a litre of water, with the neck volume added; a little more.
It's something I was interested to make for myself, sounds way too complicated to make multiples of though.
I would love to get a second oil cooler in there... Not like you need 40L of washer fluid anyway. :P
I have the advantage of being able to use my cardboard mock up for templates; I'll see what this one turns out like.
A litre odd would last long enough.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
