As i plan to really get to the track more in 2014 and get this nugget sorted so i can learn to drive it, we thought some oil control is in order as we all know RB's need it :P So even though it is still 100% stock motor and headgasket etc it now has a nice shiny sump -
455e538a-4ff7-46a3-9ef7-124f617b351d_zps
As you can see in the image here the turbo elbow is now on the housing so that should get rid of that issue!
16776f2c-58e4-4025-85ad-1a6c6fe75f55_zps
You'll still need to shield that silicon from the heat.
Get them to bend up a bit of heat shieldy stuff, and use some of the mounting points to cover the manifold. Even if you ceramic coat it.
Itll be wrapped and coated etc man! All over it :thumbsup:
Is that sump specially for Neos? I was measuring it up down there and it looked like the sway bar and some hardlines wont clear with the bigger sump.
I'm guessing your putting on a oil drain too behind your head.Going straight to the sump.
Sorry man, havent been online much lately... It fits -
21784988-49b3-4968-aa2a-5eba02cfc67d_zps
nice definitely a good aid to making these engine last a bit longer as stockers
Yep will hopefully prolong the life of the poor engine! Its had a hard life but at 150000km its still copping 25psi and 500+whp no worries... This sump will be able to stay with any engine i put in as it will always stay NEO so its a sound investment considering i want to be doing more track time.
The engine mounts were changed to a Hardrace item. Coolant sensor has been relocated to read correctly. Exhaust manifold has been wrapped & clutch plate was swapped to a solid item.
teh secks!
Still ah mazing it's the stock motor, yet people spend like $5K+ on built motors for the same effect
let's race bitch LOL
I'm waiting for my snail/paper weight to come
teh secks!
Yep, and that is why the build is staying where it is... I am happy with the way it goes (WHEN it fkn goes lol) and the motor seems to be happy enough to handle the given power so why build a motor? And if this motor lets go i will not be changing the plan, ill be finding another low milage donor and going again... I plan to use the car as much as i can and learn to drive it, SMSP South was my first chance and unfortunately a broken engine mount was causing me a lot of issues as you can see a few pages back! BUT sorted now so try again soon....
I got a few gremlins to iron out, but let's hit up wakefield for speed off the streets next year when you're free!
Fingers crossed i have found the last of them!
Will be keen for a few wakie days, just gotta work out time to do them as we are short staffed at work!
Hoping to try the car out locally if i can at SMSP or similar just to MAKE SURE there are no more surprises lol
hope so too!
my car now refuses to make any power past 6k rpm, I can't hear any audible knock or anything.. but being a remapped ECU I can't plug up any software to see what's going on (soon to change once I slap on the new turbo :) )
swapped out the spark plugs last night and was about to go for a drive and realised my fuarking license has been expired for nearly a week!
hope so too!
Lucky you didnt get pulled over :P
Needs more turbo! That is my diagnosis haha
Come to one of the SMSP twilight track days early next year if you can get a few hours off work. I'm booked in for the 30/1 and the 26/2.
I like the look of that sump, jelly :)
yezzz.. got a Hypergear SS2 and got Scotty to weld on a 45mm Turbosmart Hypergate.. now Stao is just checking the rear housing and finishing off the turbo.. should get it by next week :D
fuarkkkkkkkkkkk lez do teh screamer haha
Will do mate! If you are doing both ill try do the same! I saw the guys footage from the last one and it looked fkn awesome!
Looking forward to tracking with ya again :thumbsup:
Sump does look the goods, its got some impressive goodies inside too!
Should be the goods man! Looking forward to seeing the results!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
