When it was ready to come home for final prep prior to the panel shop we found the trailer no longer suited the car, so took to it with an angle grinder... Keen eyes will notice the front bar and spare wheel on the trailer are now missing to get the thing to fit on... We will re-assess the trailer situation once its all complete!
  • Like 1
This brings us up to date with the current progress, things are all happening VERY fast now and the car is taking shape... In the next few weeks you will likely see images of the finished product, after those the car will be re-wired, suspension modified and aligned and then its time to test...
Unloading is not so fun anymore -
Thanks to Brians Race Ramps it wasnt too painful...
  • Like 1
The car is now underway -
11755237_389579074578985_511605816879891
11223898_390192691184290_556477352224918
You can keep an eye on FB for updates on Vacy Smash Repairs FB page, give them a like and you will be the first to see...
  • Like 1
The front end looks F-ing amazing. Can't wait to see this thing.
Have those brakes been in your updates yet?
Pretty happy with it!
Ummm i thought they had, hence why i didnt post anything... Ill look back now!
Edit - There is an image here of them fitted - http://www.sau.com.au/forums/topic/358438-34geeteetee-daily-track-project/page-102
But no official update on them.
  • Like 1
Had a look and realised most of the photos from the Brakes, bodywork, underbody etc are not on this PC... But here are a couple of the brake setup from my old phone...
So the kit is the Alcon 365mm Motorsport kit from Brakes Direct, not to be confused with the street spec kits they advertise, the calliper and pads are completely different -
Ditched the old backing plates to make them fit, will run a brake ducting setup later -
Rotor size comparison -
And the finished product all fitted and bled -
11065909_821195521283706_456016235622054
The newer pics will be put on FB, but ill keep this build thread for the technical aspects and DIY images etc...
Any questions, advice or just general discussion can be kept here too! If it benefits other members then its a bonus!
My god - this beast looks amazing!!
Well done mate.
Thanks mate, really looking forward to the next few weeks as the car evolves!
Mocking up panels was one thing, but seeing them being moulded to the car and taking shape is SO much better!
11752614_392287624308130_320227999871079
  • Like 2
Man good job in that interior there. Ill have to do that at some point and im not looking forward to it.
The amount of hours grinding away body glue and crap is amazing, i spent ages on it!
Its going to look good once done, i guess nobody will appreciate the man hours involved until they attempt it themselves, i know i didnt lol
  • Like 1
HMM call me sherlock.
What colour you painting it?
Just the original white...
Call me Mr Original... lol
I plan on keeping the whole car looking plain as a GTT/R should look.
I will be keeping stickers/logos to a minimum, however the companies that have supported me so far will also have a say in this.
Apart from the roll cage..... And all the body work.... :nyaanyaa:
Since it's full stripped you should put the GTR driveline in it... Just sayin.
I just had my dad remove the sound deadning out of mine as a little project. I think it took about 18hrs spread across 3 days of -5c. Not looking forward to rubbing it back. Yours looks way nicer inside and will look mint with a fresh coat of paint!!
I would have just built a GTR if i wanted that, i wanted RWD and something a little different...
I love driving the rwd GTT but also always preferred the GTR look... So figured why not have both!
It is not a nice job!
I found the glue was the worst part, i guess as they know it will be covered in carpet etc that they just dont car what it looks like but they managed to get it everywhere and it is really stubborn when you try to remove it! I went through quite a few wire wheels...
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
    • The frontend wouldn't go low enough because the coilover was max low and the upper control arm would collapse into itself and potentially bottom out in the strut tower. I made a brace and cut off the kingpin and then moved the upright down 1.25" and welded. i still have to finish but this gives an idea. Now I can have a normal 3.25" of shock travel and things aren't binding. I'm also dropping the lower arm and tie rod 1.25".
    • Motor and body mockup. Wheel fitment and ride height not set. Last pic shows front ride height after modifying the front uprights to make a 1.25" drop spindle.
