  • Replies 743
apparently due to the B clutch over heating by slipping. this caused extreme heat in the b clutch housing (tightened and locked with loctite).
as a result of the heat the housing has loosened and the clutch would not operate so the gear selector is trying to engage without releasing the clutch which resulted in the broken selector fork.
not sure why the clutch was slipping.
two things thought to contribute to slipping are incorrect torque tables and left foot braking. our torque tables were spot on and we uncovered no overlapping left foot breaking on review of both mine ad Tarzan's data.
gots to love warrenty
Below is a bit more information about the radiator and oil cooler that we are building for the Mercury/Qscan R35.
The radiator and engine oil cooler cores are the latest in "stepped core" technology. These particular units are designed to be mounted at an angle of 30 degrees yet the ambient air flow through the core is still parrallel to the ground.
Below pic is actually for an STi.
We decided to make the end tanks from solid billet ....they are still feather weight being 2.5mm thick.
finished product
We are very excited to be a part of this project...can't wait to see the car back on the track.
Next job is a pair of very trick intercooler cores.
Kev
Given that the end tanks have to be welded to the core, the inlet outlet hoses have to be welded in I couldnt see the extra bit of welding on the end folds making any difference to the the integrity of the unit.
I've yet to see a quality radiator split on a fold or anywhere else for that matter but if these guys want to show their mad skills by carving up a billet block then good for them.
Everything is billet these days... new fashion!
guys I have posted up a list of my parts for sale.
engines, performance parts, carbon and OEM parts stripped off the cars with low milage (some are new or near new).
also a vbox pro version with 16 channel logging and 2 cameras with a bunch of extras.
see the links in the sig
in addition to the awesome work done by the mercury lads we have James McCabe on board this year (race engineer) and luke at 4race (composites construction)
both fantastic guys and very passionate.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
