If you buy a genuine Walbro you should have no issues, it's the knock offs causing the confusion.
I have twin 255's intank and have been running them for years on e85 without a problem. These days I would go for the e85 416L version just for the sealed plug and the fact they are designed for long term ethanol use.
I wonder if my Nismo pump will last long term on ethanol. I haven't heard anything bad yet about the e85 walbro pumps so they must be a good upgrade from the standard pump.
Nismo over engineer their things, im sure they would have had race gases similar to E85 being tested with the pump during their their RnD. Im slapping mine in soon hope it lasts.
Since this discussion is ongoing...I'd like to pose a question...
How much power roughly do you think a single Sard 280LPH intank pump would support on a 2JZ?
I'm at 325rwkw atm on eflex but I'm thinking of turning the wick up alittle more...
"If you buy a genuine Walbro you should have no issues, it's the knock offs causing the confusion.
I have twin 255's intank and have been running them for years on e85 without a problem. These days I would go for the e85 416L version just for the sealed plug and the fact they are designed for long term ethanol use."
In regards to the Nismo pump, I'm running one on e85 with no problems at all. I stayed away from your standard Walbro pump just from the fact that they have a higher tendency to fail. I know a few guys who have had problems after a period of time.
I've heard this too. So i was never convinced the walbro were perfect little gems to begin with. Thats why I had no problems deciding to give This is the "fake" walbro pump a go as well
http://www.ebay.com.au/itm/GSS341-Type-340L-H-Performance-Fuel-Pump-Skyline-GTR-RB20-RB25-RB26-R32-R33-R34-/110983052442?pt=AU_Car_Parts_Accessories&hash=item19d71afc9a&_uhb=1
They claim 340L/PH. I"m not sure if anyone has verified it. I did get a genuine 255 too. Didn't notice any difference in the way the car ran between the two.
Anyway I will think about cleaning the injectors, or possibly buy another set for not much more than clean. Boost is staying low for now.
Can anyone extract any data out of the spark plugs?
Red spark plugs? hmmm.
Edited by sonicz
I would be curious to know as well. I will try and squeeze every kw out of my nismo pump before I need to move on :)
What's generally the limit i.e. maximum power for the nismo pumps?
RHD says 550ps and im sure it will get there and probably over.
regarding the walbro 450lph E85 fuel pumps....what power have people made with these and at what boost (psi)? have we found the limit of these pumps yet??
They are rated @ 450lph @ 0-30psi... A stock RB fuel rail runs a higher base pressure than that :whistling:
Once you get them to 60-70psi (which is what most people will be running), the flow drops to under 400lph, maybe even 360lph - I saw the rating graph from Walbro 450l a few weeks back but for the life of me i can't find it right now.
Gotta love the online retailers at the moment claiming they will support "900hp on a turbo set-up", maybe if you used two they would.
Haha exactly right
I'm running one getting 13.8volts, with my base pressure at 55psi and 26psi boost it made 410rwkw on e85,
Obviously lower and or stock rail pressure and lower boost will net more flow
I have been recommended by quite a few knowledgeable tuners recently to bump up my base pressure, (I am running 40 psi with the hose off) The bosch ev14's apparently spray a beautiful mist at 90-100psi but there aren't any intank pumps out there that flow much at such high pressures, certainly not the 255 twins I have currently.
To test my theory (more pressure = finer mist = better power and economy) I would need a large mechanical gear pump off the fuel cell, I am thinking one of these Magnafuel external pumps which are rated up to 120psi.
http://www.magnafuel.com.au/index.php/efimenu/efipumpsmenu/protunermenu
Might be time to ditch the twin intanks I think.
Yep injectors needed abit of help and also idles better so maybe the higher pressure is atomizing better?
My next step besides cams cos my stockers are holding me back would be 2000cc injectors and maybe a fuel lab external pump
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
    • Do this, and we'll have a resource right here.
    • "Hybrid" is a meaningless term. I could not tell you what the vendor of that turbo means by "hybrid".
