We did the other rear guard yesterday. It went even better than the first. I now have 265/35/18 tyres fitting all round! Hopefully the AO50's that I'll be running later in the year aren't wider than the RE55's...
Awesome stuff. Love the R32's. Great to see you enjoying it on the track and loving it.
Any weight reduction plans?
Not really except the sound deadening has already been removed.
How much u pick up the A050 tyres for?
Haven't bought any yet. I'm expecting around the $550/tyre mark
I like your style of guard mods, overfenders = FAIL.
I don't mind the overfenders but this worked out and was cheaper too.
I remember reading somewhere the 050 were a bit smaller than RE55's mate in 265...
Hope recollection is correct.
Love the car, love the build.
Following it all on FB for a while now, must find time off work for SL 2011 :D
Top stuff mate. Should get you back into the top 10 on the EC track times!!!!!
What is the goal at EC?
Yeah should get me in top 10 again haha.
I would like to go as fast as a 1min 42 but I don't think it will be this year. Maybe 1:44. Realistically it's a whole lot more car than I'm used to and it will take a while for my driving to catch up.
With 330rwk, bigger brakes, lighter car and the 265 A050's, you will go a lot quicker than 44's! Sure, it may take a track day or two but definitely some good times to be had. Should be fun with 330rwk!!!!!
Will be more like 280-300 as motor is internally standard. E85 could be a possibility in the future for over 300. Not sure yet. Whatever is safe really. Don't want a grenade engine.
*face palm for buying this motor*
That thing will go strong for a lot longer. Compression was good when we pulled it out and had a great tune with very low knock levels.
You election not to go for the 295 Advan Russ?
All that work is a mild waste for a tiny little 265..... :P
295's wouldn't work on the front unless I go for GTR uprights. I'm already running a 10mm spacer for inner clearance. 30mm doesn't seem like much but when you consider that we've already stretched it ~50mm, 30mm is lots more!
When you make 295's fit on yours I'll copy you :P
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
