I'd say its all about drive line. When you look at (I know you already would have...) Craigs vid of his stall launch, you can see the punishment that it cops. However-
I think the more and more you guys find out about the VQ25det, the more I see that nissan have choked it from factory- Intake pipe, THAT dump pipe, the throttle, the untuneable computer etc etc.
I think that they would have had a situation on their hands if these stageas started cutting in on their sports market. I mean, it doesn't take much for a Stagea to rip a CPV35 or a Z33. Wouldn't be a good look for Nissan to see the Wagon passing the "sportscar" down the highway!
YES ! I agree & continually thank Nissan for designing an engine that was too good for it's intended purpose and/or market. It means one only need spend a few thousand to remove the breathing restrictions & some electronic ones & it turns into a completely different animal. Maybe the engine guys misread the memo & thought the car was going to weigh 3 tonnes, not 2, & designed it accordingly, lol.
Or, more likely, one of them wanted a Stagea and was making it easy on himself for later. In any case, way to go boys :worship: .
  • 1 year later...
Anyone interested in this again? I would like a re-map as I'm not getting any of the tards in this state to touch my car with an emanage. Do you still have the Japanese translating contact Ryan?
Get on it & report back with your solution.
Good luck.
Sorry Rich, the translating contact was through someone at work who is on maternity leave, so not easy to get them to pick it up.
The guy at G-Zone speaks little to no English. If you're really dead keen, I'd get Jesse Streeter to do the gophering for you and just pay his commission The Japanese lady who was doing the translation for me didn't understand cars, and that made things much harder.
I've gone F-con myself, there are a few other benefits to going with something like that. But is there really NO ONE in Tassie you can trust to tune it?
What Nismo ecu is this? It's difficult down here as no oe that I know of has tuned E Manage and there are only 3 or 4 dyno's I know of.Getting on the boat makes it a very expensive exercise in the end.
My mate has a 2012 wrx sti.
He got a tune for his car online for $100 includes data logging sent back to the guy to adjust it.
Life isnt fair.
Mail order tunes are shit no matter how much data logging you do.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
